Which engine?
Old Dec 5, 2002 | 11:40 PM
Toptul_Honda's Avatar
New User
Default Which engine?
1. Whats the best D-SERIES engine to use for an ALL MOTOR streat beast?
2. What kind of high compression pistons can you use? Rods? Crankshaft? (AFTERMARKET)
3. Hows the d16y8 vs the d16z6 and d16a6 and d16z7? (which one better for N/A Buildup?)
4. Which is going to give me strongest bottom end?
5. What kind of bottom and head to use?
6. And most importantly, if built up right, how much power do you think i'll be making?
7. Transmission
[Modified by G2-Rex, 9:11 AM 12/6/2002]
[Modified by G2-Rex, 6:32 PM 12/6/2002]
Old Dec 6, 2002 | 04:55 AM
altoid's Avatar
Default Re: Which engine? (G2-Rex)
search will tell you
Old Dec 6, 2002 | 08:09 AM
New User
Default Re: Which engine? (altoid)
sorry didnt find anything i wanted..
Old Dec 6, 2002 | 02:39 PM
New User
tt
Old Dec 6, 2002 | 03:05 PM
Malgerus's Avatar
Best setup for N/A:
D16Z6 Block, D16Y8 head, intake manifold. (higher compression. the Y8 head is a better design, but the Z6 bottom end is stronger.
Old Dec 6, 2002 | 05:33 PM
New User
Default Re: Which engine? (Mr. S)
WHo makes good high compression pistons for d-series
Old Dec 6, 2002 | 06:04 PM
cr-x si's Avatar
You might want to think of this option. There is a guy i see down the local drag strip and he is running an all moter zc. He has everything on this motor
crx si
zc
si tranny
Port and polish
I/H/E
High compresion forged pistines and rods
Board TB
custom intake manifold
AEM Cam gears and pullies
chiped ecu (not sure which one)
stage 4 clutch w/ lightend flywheel
i belive crower cams.
Thats all i can think of off the top of my head. Anyway he is running low 13's on street tires. Not sure what his hp or torque is but im sure it pretty high
Just a suggestion.
Old Dec 6, 2002 | 06:57 PM
New User
Default Re: Which engine? (cr-x si)
ZC is DOHC right? isnt it hard to find parts for it?
Old Dec 6, 2002 | 07:02 PM
EFing8's Avatar
ZC is a DOHC and yes, parts can be hard to find. Frankly, i see more potential in a d16z6 or y8. Cost is not much higher if at all and you have a lot more parts to choose from. Plus you get vtech and that is always a good thing
Old Dec 6, 2002 | 07:18 PM
CHRIS 1.8's Avatar
Search button for the 213901209389120 time.
Old Dec 6, 2002 | 08:08 PM
altoid's Avatar
Default Re: Which engine? (B16A1-EF8)
its vtec, and what about that a6 rumor that its the strongest d series block because of its webbing or some shizzle
Old Dec 6, 2002 | 09:02 PM
slowman's Avatar
I took way too long
The D16A6 is a great engine. Here will be my setup:
P and P Head
Cam
Skunk2 Cam gear
Header
Intake
Exhaust
shooting for a 14.9.
Old Dec 6, 2002 | 09:12 PM
1.8Tities's Avatar
Default Re: Which engine? (slowmanEF)
P and P Head
Cam
Skunk2 Cam gear
Header
Intake
Exhaust
I'm on the same step:
my d16a6 set-up
Crane Cam Stage 1 installed
Header 4-2-1 installed
AEM/fabricated CAI installed
D16y8 Intake manifold with teg TB ready to install just need a B&M FPR
AEM cam gear searching rite now at classified for use one lol
many more to come
Old Dec 7, 2002 | 12:37 PM
New User
Default Re: Which engine? (4thGSi)
i want to get the most power out of it and hit the 13's hopefully in my 88 CRX
which tranny to use? the newer EX(US) or Si(CDN)
AwwsChwA
14
Nov 21, 2011 09:33 PM
89efDUSTY
Feb 10, 2007 10:55 AM
spooncivicsi
Nov 7, 2006 06:47 AM
EJ2-Fluffy
21
Oct 9, 2004 06:34 AM
93slmdcvcsi
10
Jun 18, 2004 09:04 AM
