injector question
Old Dec 5, 2002 | 10:38 PM
matt j's Avatar
Default injector question
i am going to be running a turbo on my d15 (ya i know its the shitty d15) and i was curious if there were any injectors bigger than stock that i can use, and remember it is the dpfi system.
thanks
Old Dec 5, 2002 | 11:07 PM
Vinceg99's Avatar
Default Re: injector question (hybridturbo89)
I wouldnt even waste your money putting a turbo on the DX with DPFI there wouldnt be good enough fuel managment with the DPFI injectors you would probably end up making it knock. Go and get the intake, distributor, injector resistor box, and ECU do the MPFI swap then turbo you will notice a hell of a difference just with the MPFI swap and then on top of that a turbo would be nice!!
Old Dec 7, 2002 | 06:19 PM
MADEINIRAQ's Avatar
with just the mpfi swap, you'll almost have as much power as a turbo dpfi.
Dpfi can eat ****.
Old Dec 7, 2002 | 07:08 PM
Aphrodavid's Avatar
DONT DO IT, seriously. waste of time and money
Old Dec 7, 2002 | 07:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: injector question (EF Sleeper)
Do the MPFI swap. If not then get and SMC and some 450cc injectors to control them with youll be in good shape. MPFI is worth the swap though and I highly suggest it.
Blaze
Old Dec 8, 2002 | 05:17 AM
civicwagonman's Avatar
Default Re: injector question (Blaze45)
theres a turbo dpfi on homeadeturbo.com that uses a controller box to run a separate injecter to feed the extra fuel. its definately faster than a multi-injection setup. IM abaz hes the owner of the site, since its down for reconstruction right now.
Old Dec 8, 2002 | 10:33 PM
matt j's Avatar
Default Re: injector question (civicwagonman)
ya civicwagonman i got the idea from i guy named dan from that site, he has the turbo 1.5 crx dx. he is using the stock injectors but is using a new pump. he has 320000km on his which i figure is around the same as mine, i just wanted to be safe and see if there was a aftermarket injectors that will fit on my application. i guess i will call RC engineering tomorrow and see, since i cant get a straight answer off of the board.
range hadies
Mar 12, 2012 10:42 PM
MotoCARR
Dec 10, 2006 08:26 PM
menappi
Jul 9, 2005 03:36 PM
honda89
Aug 9, 2003 01:33 AM
wrXtian
10
Sep 17, 2002 08:09 PM
