Lots of problems
Old Dec 5, 2002 | 10:25 PM
wannab20hatch's Avatar
Default Lots of problems
I got my auto to manual done and now im getting codes 10 and 14. Ive replaced both of those sensors,reset ecu and still got codes. my vss is unpluged and im not gettin a code 17 could it be my ecu is bad? Also could someone post a picture of vaccum diagrams maybe a leak somewhere?
Old Dec 6, 2002 | 08:42 AM
Default Re: Lots of problems (wannab20hatch)
Old Dec 6, 2002 | 11:45 AM
Drumwurks's Avatar
Do a propane test for vacuum leaks. Just take a heating torch, don't light it, and just let the gas flow over your vacuum lines while your car idles. If you hear it start to rev up, you have found a vacuum leak.
If not, find a known good ECU, and plug it in. See what codes it give you if any. if you get no codes, you ECU is bad. Time to upgrade ; )
If you still get codes, make sure your sensors are working correctly. 10 is Intake air temp, and 14 is Idle air control. Maybe there is a broken wire, or bad ground in the harness for either or both of those sensors. test that.
There isn't really anything else it could be. Good luck.
Old Dec 6, 2002 | 11:46 AM
Drumwurks's Avatar
Default Re: Lots of problems (Drumwurks)
Another thought... are you still using the auto ECU?
Old Dec 6, 2002 | 09:59 PM
nope using a dx manual ecu
Matthew98DX
16
Mar 1, 2017 06:05 PM
InvaderTrax
Jul 16, 2007 07:20 PM
dad0c402
May 5, 2007 08:06 PM
DrewMD
Feb 22, 2007 11:34 AM
skiracer8148
Feb 9, 2007 01:30 PM
