b16a crankshaft in b18a???
would a first gen b16a crank work in a b18a block (for lsvtec)????? or is it worthless?????? just wondering because i read that the GSR crank can be used so that you can rev higher....
thanks....
thanks....
why bother with this? are you afraid an lsvtec cant rev high enough for you?
i wouldnt even consider using the GSR crank in my ls block because its just a waste of money. if anything you could do the 'long-rod' setup which requires a .137" longer rod (compared to OE LS rods) and custom spec pistons so that you would then have a 1.58:1 r/s ratio like the GSR/ITR motors. but i cant justify the extra $$$ just for the GSR r/s ratio not to mention a slight loss of displacement from doing the 'long rod' setup. i'll take my chances.
otherwise if you have the money then just get a GSR block to begin with.
crxtreme27
Dec 6, 2002 08:57 AM
