Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2?
Old Dec 5, 2002 | 09:21 PM
MeanGreenEG9's Avatar
Default Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2?
Need answer from someone who is using this or knows someone who does use it. Thanks in advance.
Old Dec 5, 2002 | 10:11 PM
Mike95lude's Avatar
Default Re: Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2? (Junek9)
Yes it will.
Old Dec 5, 2002 | 10:24 PM
.(Lazarus).'s Avatar
Default Re: Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2? (Mike95lude)
still trying to find an ecu? Just chip your p28 with p30 maps.
Old Dec 5, 2002 | 10:27 PM
mmuller's Avatar
Mad Scientist
Default Re: Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2? (ATXhybrid)
It would be the same
Old Dec 6, 2002 | 12:01 AM
sgT's Avatar
sgT
if you have a del sol, you wil need a harness adapter.
the ecu only plugs in to 99-00 civic and 00-01 integra
Old Dec 6, 2002 | 06:21 AM
Default Re: Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2? (sgT)
Where would I find a harness adaptor to fix the si ecu? is there any that will just fit other than the del sol vtec ecu?
1997b16a2civic
11
Mar 31, 2010 12:10 PM
Honda4life777
Jul 9, 2009 07:19 PM
Username001
May 18, 2008 12:55 PM
gulftiresinc
Dec 14, 2007 04:36 PM
MeanGreenEG9
Dec 1, 2002 09:52 PM
