00 ITR dyno #'s
Old Dec 5, 2002 | 08:48 PM
SergEK's Avatar
Default 00 ITR dyno #'s
Well my friend and I went to the dyno for some baselines and tuning. I hit 165.5 @7900 and 124.0@5900 which had me disapointed.
After reviewing my elevation factor 2700ft+ the numbers look a little more in the ball park.
178.90 and 134.04 aem short ram, dc pos 4-2-1, tiny 2.25 tanabe cat back + me tuning VAFC.
Do my numbers look about right? I am using an Si ecu (P73 coming) and used the A/F readout to tune....stays below 14:1 the majority of the time and goes rich around 7500+ (still high 12's).
Will try to scan dyno and A/F monday.
Any thoughts? Also 00 is the year the intake cam was upgraded tp CTR spec right? I have a semi flat line from 7500-8000 which I had heard was a trait of the older 97-98 cam. Anyone else experience this?
Old Dec 5, 2002 | 08:59 PM
itr1244's Avatar
Default Re: 00 ITR dyno #'s (SergEK)
Good ish
Old Dec 5, 2002 | 09:00 PM
disordeR's Avatar
how did you correct your numbers? those numbers look.. high.
Old Dec 5, 2002 | 09:05 PM
SergEK's Avatar
Default Re: 00 ITR dyno #'s (disordeR)
(elevation*.03*dyno hp) / 1000 = hp loss due to thin air add that to original #'s = sea level #'s
Old Dec 5, 2002 | 09:08 PM
disordeR's Avatar
well you sir.. have an incredibly strong car...
OR..
it's your dyno. but either way, 165/125 uncorrected are still fairly good numbers.
Old Dec 5, 2002 | 09:15 PM
SergEK's Avatar
One of two chassis dyno's in my current state of Idaho...tough for me to compare other numbers.
However I will be home in the spring for a clutch/flywheel upgrade so I may stop at Import Builders and get a before and after P73/fly/clutch swap.
If it helps justify the #'s I run a 14.09@ 97.7 @2700 ft with a 2.08 60' (drag radials) only reving to 8000 rpm.....13.63@101 corrected for elevation.
2550 with me in it. Do the #'s run with the ET's?
Old Dec 5, 2002 | 09:17 PM
disordeR's Avatar
those are NICE times. only person that i know who can run close to those times with a relatively stock car is Activeaero.
Old Dec 5, 2002 | 09:20 PM
Casey's Avatar
pretty high tq, good hp
Old Dec 5, 2002 | 09:30 PM
SergEK's Avatar
Thanks for the props...I was wondering just how they were compared to others??
http://www.firebirdonline.com/Banque...q02_champs.jpg
I am in the front row, far right.......2002 "Import" Track Champion. (rookie season )
Motor has surprised me....but I know there i still a few hp left in it with just a little more tuning, a bigger header, 3" exhaust ( I run open at the track) and the P73....13.70's here (2700 ft) is what I am expecting maybe better if I can hook a 1.9 or so on my bfg DR's.
Old Dec 5, 2002 | 09:51 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
But I do it without drag radials. 2.05 60' on full street tires ownz drag radials yo! Just kidding. Nice times.
Old Dec 5, 2002 | 09:59 PM
disordeR's Avatar
Default Re: 00 ITR dyno #'s (ActiveAero)
lol. you're a great driver regardless...(dunno about through the twisties though)
Old Dec 5, 2002 | 10:02 PM
SergEK's Avatar
Thanks....good job with streets...I end up lighting those things up to 2.3-2.4 I can only imagine running on them at sealevel...spin city for me
So do the numbers look TOO high or just a little high?
EDIT: Wanted too add this ?..... Could I squeeze a little more hp with some cam gears? I feel the intake could use a little more advance...the motor seems to run out of breath around 7700 then starts dipping at 8000. I want to try to squeeze as much hp as possible this year and JUN cam gears are cheaper than a stage 3 cam setup...also I noticed I am running out of fuel adjustment for my motor in VTEC....should I replace the DX pump now? Or wait for 185+ numbers to change it out? FPR?
[Modified by SergEK, 11:07 PM 12/5/2002]
Old Dec 5, 2002 | 10:05 PM
disordeR's Avatar
with those mods, i'd say high 160's low 170's...
Old Dec 5, 2002 | 10:11 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
One 1st, and two 2nds in STX in AL region Solo II out of 3 events (rookie season).
Posted 3rd fastest time of the day twice once in another region. Placed 2nd in STX in the pouring rain against 5 WRX's. Do I still suck...yes. As bad as some...no. Do I like bragging and being concieted.....of course its the internet yo!
Those numbers sound right to me considering your times.
Old Dec 5, 2002 | 10:13 PM
vtec.dc2's Avatar
if 165whp was SAE Corrected numbers, then theres nothing else to correct, I'd think most if not all dynos can show SAE corrected numbers, other than CF might be off a little, if on very hot summer day.
Old Dec 5, 2002 | 11:27 PM
SergEK's Avatar
Default Re: 00 ITR dyno #'s (vtec.dc2)
Hmm I will ask him but I didnt see SAE anywhere on the chart....I will ask the dyno owner and maybe he can set me straight....I was hoping for at least 170...but maybe I only have 165 oh well....
Old Dec 5, 2002 | 11:29 PM
disordeR's Avatar
Nice.
you should drive on a road course too! that's fun as well.
Old Dec 5, 2002 | 11:41 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
I know I'm trying to get on one. I heel&toe at autocross to be cool .
<wants to be a professional race car driver because he is stupid and likes having no money .
Old Dec 5, 2002 | 11:44 PM
B2FiNiTY's Avatar
Heel-toe at auto-x? Lol. I'm always just stuck in 2nd.
Old Dec 6, 2002 | 12:24 AM
ablangc's Avatar
Default Re: 00 ITR dyno #'s (B2FiNiTY)
I have a 99 civic ex with a 00 b18c ITR engine with the following mods: p73 ecu, aem cai, jdm 4-1 header, high flow cat, greddy sp exhaust, and 255 lph fuel pump. I just had it dynoed 1 month ago on a superflow chassis dyno at sea level and put out 180.4 whp at 8036rpm and 126.7 at 6260 rpm. We pretty much put out the same numbers!!
Old Dec 6, 2002 | 06:40 AM
Hooch'n's Avatar
Default Re: 00 ITR dyno #'s (ablangc)
: nice #'s
Old Dec 6, 2002 | 06:47 AM
Chris N's Avatar
Default Re: 00 ITR dyno #'s (Hooch at 8400-RPM)
The torque seems rather high. I recently had 175/125.4 with J's intake, JDM DC 4-1, test pipe and Fujitsubo RM-01A. untuned. I'm not so sure about that correction equation, few of us are at sea level anyways. I'm not saying those numbers are WRONG, but given your mods, that torque seems pretty high. HP looks good, though. Wierd... Anyways, nice numbers.
Old Dec 6, 2002 | 11:18 AM
ablangc's Avatar
how did you get the equation for the torque because at sea level I am only putting out 126????
Old Dec 6, 2002 | 05:33 PM
stupidfast's Avatar
I was there at the dyno with Sergio and I can verify those numbers.. He dynoed those numbers without the elevation corrected..He has a strong setup..
Ps. He had his exhaust unbolted at the header I think thats why his torque was so strong. He had the hump in the midrange that was really nice. Car is real fast with the mods he has. 14.0 on street tires, i Know he's whooped me once or twice on the track..
Hollister Punk
Jun 14, 2004 04:43 PM
cegleitz
Jul 23, 2003 09:08 PM
VTHokie
Apr 21, 2003 04:41 PM
RATEDR
Jul 21, 2001 12:19 PM
bussetech
Jun 25, 2001 12:14 PM
