Kosei Wheel, Eibach ERS Springs, 92 GSR Parts
All parts are from 92 Integra GSR unless noted, may fit other Honda products. All are used but in near perfect condition unless noted "new". Buyer pays shipping. If you don't like the price talk to me. Do not email me if you are going to flake. Do email me at msasso@interchange.ubc.ca if you are serious. Or Contact Marc Sasso @ 604 736-6501, located in Vancouver, B.C. Price in US dollars.
White Kosei K1 Racing Wheels +45 X 7 X 15", 4 X 100mm mounted with the remains of Toyo 205 X 50 X 15" RA1 Tires $395.00 Will throw in 2 unmounted RA1's with about 20 to 25 solo runs left on them.
1 set of 4 Ground Control sleeves for Koni yellows front and rear, no perches $ 45.00 "new"
1 set of 2 springs Eibach ERS 2.5 X 500lbs X 8 " $85.00
16 McGuard Lug nuts, 4 locking with key, radius seat for Honda/Acura wheels $20.00
Porterfield R4 front brake pads 75% $ 40.00
Stock Acura 98 Integra CD/Radio with theft code card, fits stock 93 G2
plug in and mounting $ 75.00
Front speaker mount cages and speakers $8.00
Energy Suspension Front Radius rod bushings $ 10.00
Rear Compensator Arms $15.00
Rear Upper Control Arms $20.00
Front Damper Forks $35.00
Rear Compensator Arms, pair $15.00
Hazard Warning switch $ 5.00
Rear Defogger switch $ 5.00
B17A1 Throttle body, missing idle air screw and TPS $ 40.00
B17A1 Fuel rail $ 15.00
Rear Windshield Wiper assembly, complete $ 35.00
B series Cam Gears B17A1 $ 5.00 each
B17A1 Intake manifold support bracket $ 15.00
YS1 gearbox differential with bearings $ 45.00
B17A1 VTEC intake camshaft $ 40.00
Front and Rear Tow Hooks $ 2.00 each
Upper Alternator bracket $10.00
Front mud flaps, pair $ 10.00
Stock Black plastic battery box $ 4.00
Rear 14.7mm anti-sway bar from 93 GSR $ 15.00
Rear 15.9mm ant-sway bar from 93 4D GS $ 18.00
Front calliper slide pin boots Honda PN 43234-SD2-931, 4 pieces $ 2.00 each new"
Front calliper seal rebuild kit, 2 pieces $ 10.00 each "new"
Rear calliper seal rebuild kit, 2 pieces $ 10.00 each "new"
Hood lift rod $ 2.00
Hood leading edge trim $ 5.00
Rear view mirror support damper $ 1.00
Brake booster check valve bracket $ 2.00
Power steering pump pulley $ 2.00
Rear shock top covers, pair $ 1.00
Peddle covers rubber, gas, brake, clutch $ 1.00
Stock Front Radius rod bushings, pair $ 2.00
Spare tire never mounted $ 20.00
Stock lug wrench $ 1.00
2 Stock Front Seats, graphite black $ 250.00
Some Stock rear interior from front seats back, will separate $120.00
Graphite black rear seats, rear folding shelf deck,
L & R side rear pillar trim panels,
L & R side shelf speaker mounts, speakers, hatch trim panel,
trunk deck, black plastic. Also all the small black trim pieces like the
hatch damper bolt covers.... , Etc.
Stock Front Brake callipers and rotors, will separate $65.00
Most Stock ABS brake system, will separate $100.00
ABS Control Unit, Accumulator, Modulator, 2 front Wheel sensors,
Relays, Connectors, Etc.
1 set of new 4 door rear floor mats and front passanger mat,
graphite black $ 15.00
WANTED, Heater Duct, Part "9" in this picture.
Heater Duct
Roof Panel, non sun roof from salvage car, pick up, NW local only.
[Modified by DB1-R81, 10:10 AM 12/6/2002]
Heater Duct
diadoraz10
May 26, 2007 11:14 PM
