window off track...won't close properly
Anyone else have this problem with their rex? I have taken the door panel off and tried to align the window but it keeps not closing right. If I roll the window all the way down then it rolls up fine about 3/4 way up then the back part hangs out about 1/4". It goes out and stays forward alittle bit. I hope this makes sence. Anyone got anything I can try?
I didn't think you could just replace those arms, but i have been wrong many times before so this would not be a first. I wonder if I could use the one from the passanger door? I have a spare passanger side door.
I was having the same problem and I ended up loosening the rails on both sides and moving them in. Another thing that was wrong with mine is there are little round plastic like slides? that it actually moves on sometimes they go bad check and see if they are popping off of the regulator
(i doubt its your regulator)so far mine and my closest friends CRXs have had this problem.. we used jb weld and 2 tone epoxy to hold them in place. when you open the door up fill the feet with the mixture and make sure that the sides line up with the tracks on the door.... the best advice i can give is, have a friend help you(to hold the window up) and take your time!!!
Hpoe this helped
[Modified by k4ff1n3, 9:20 AM 12/6/2002]
Hpoe this helped
There are a lot of moving parts on this thing. Could you give a better description of what to do or even a pic.
ok...it stays on track and closes properly if i push up underneath the front part of the window. but i can't find anyway to keep pressure applied that way.
8YourV8
Dec 13, 2010 10:09 AM
Jonathan_ED3
May 9, 2005 11:42 AM
.ShawnD.
13
Oct 27, 2002 02:25 PM
