oil jet bolt thread stripped
i was starting to put my b16 together when i found that my 1 and 4 cylinder oil jet bolt threads are stripped. i also found out they dont make heela coils that small either so im stuck. anyone had this happen to them? anyone have ideas? need help asap, im so close to vtec.
the same thing happened when i was putting my b18c1 back together. i stripped out the number 4 oil jet. we just plugged it and went on with life. im not sure about having two of them plugged. i was told if you bore a 1.8 b18c1 to a 2.0 then you cant use the jets anyhow and that engine will run good. or look at the ls-vtec they dont have them. although on the other had if you can find another block why not get it and start fresh.
Keith
Keith
then you have to make a perfect hole in that new bolt or else oil wont flow through it. me and a friend are going to try this at a machine shop. ill let you know how it goes.
carlton585
Jan 8, 2005 12:29 PM
