88 si tranny, what flywheel..
Old Dec 5, 2002 | 07:08 PM
CimorelliCRX's Avatar
Default 88 si tranny, what flywheel..
i know this has been asnswered 1000 times, but i couldnt find it in a search, what flywheel do i use with an 88 si tranny, 88 i am guessing, but can I use a 90, and just an 88 clutch, or will it not work, and only work with an 88?
I am wondering cause i used a 95 ex flywheel on a 90 si tranny once and it worked so.. i am guessing all d sereis flywheels are the same no matter what year the difference is just the clutch...
Old Dec 6, 2002 | 01:25 PM
Default Re: 88 si tranny, what flywheel.. (CimorelliCRX)
ttt
Old Dec 6, 2002 | 02:08 PM
zCivic's Avatar
88 flywheel only, 88 trannys use a smaller clutch disc along with a different spline on the imput shaft.. If you go with another flywheel have to use a different cluch disc and wont work...
Old Dec 6, 2002 | 02:37 PM
ppavis's Avatar
Default Re: 88 si tranny, what flywheel.. (zCivic)
Correct. 88 tranny has different splines than 89-91 and smaller clutch pressure plate so... Need to stick with all 88 equipment.
Old Dec 6, 2002 | 03:15 PM
Default Re: 88 si tranny, what flywheel.. (ppavis)
Alright I thought so, ahh well. Thanks guys.
Old Dec 6, 2002 | 06:28 PM
civicwagonman's Avatar
you can use a 92 up flywheel and pressure plate and a 88 accord clutch disk. works perfect. have it in my wagon cause all I could find was an 88 awd trans.
Old Dec 7, 2002 | 09:23 AM
zCivic's Avatar
Default Re: 88 si tranny, what flywheel.. (civicwagonman)
Thats a new one on me. So you have a 88 tranny with a 88 Akkord cluch disc on a 90-00 Flywheel, on a 94 Z6. Well That is tha **** because I just checked on ACT and the 88 Akkord uses a 212 MM clutch disk and also check a old 87 Akkord tranny and its 21 Spline. That is the coolest thing I've heard all day. Use a 90-00 Pressure plate or did you use the Akkord pressure plate??
Old Dec 7, 2002 | 01:13 PM
altoid's Avatar
dude its accord
Old Dec 7, 2002 | 03:15 PM
Default Re: 88 si tranny, what flywheel.. (altoid)
I have the 88 accord clutch disk with the 94 flywheel and pressure plate.
Old Dec 7, 2002 | 04:53 PM
Steve91's Avatar
I run an 88 tranny in my 91 SI. I run the 91 flywheel (212mm) and use the "88 Upgrade" disk from ACT. This disk has the size of the 90-91 but the center hub splines fit an 88 input shaft. DON'T use an 88 clutch, its only 190mm
Old Dec 10, 2002 | 10:53 AM
Default Re: 88 si tranny, what flywheel.. (Steve91)
So basically all I need is the 88 clutch disk, but i can use a 91 pressure plate and ****?
Old Dec 10, 2002 | 11:12 AM
zCivic's Avatar
uh no, you can use only the 88 civic cluth disc/pressure plate with the 88 flywheel, you can get a upgrade like ACT sells or try the 88 accord (is that better) idea and that would work with the 90-00 flywheel. 88 clutch disk itself is a different input shaft 21 spline and smaller disc/pressure plate.
Old Dec 11, 2002 | 09:08 PM
anyone have a 88 flywheel for sale? lol
Old Dec 11, 2002 | 11:18 PM
Urban Business
Guest
Posts: n/a
must remain 88: flywheel and disc
pressure plate can be a non 88
Old Dec 12, 2002 | 04:42 AM
zCivic's Avatar
Default Re: 88 si tranny, what flywheel.. (TorteX)
never accually messed with the 88 tranny but willing to bet if the clutch disc is smaller and the fly wheel is smaller, have to use a smaller pressure plate. In this case 88 clutch, 88 flywheel and 88 pressure plate.....
Old Dec 12, 2002 | 04:55 AM
spun Vtec's Avatar
if your going to race it i would deff use the 92 flywheel and pressure plate with the 88 accord disk i know the 92 flywheel is deff ALOT bigger than the 88 and a good bit bigger than the 90-91 if you are modifieing your car it is deffinately a major improvement over the 88 stuff good luck
Old Dec 12, 2002 | 05:13 AM
Default Re: 88 si tranny, what flywheel.. (4gsicivichatch)
the 88 si clutch disk won't even catch as much in a 89 up flywheel as it does with the stock 88 flywheel. gotta use the 88 accord disk with 90 up flywheel and pressure plate.
user 98292739
May 6, 2007 12:32 PM
Floored
Jun 8, 2005 06:59 AM
gutted-dx
10
Apr 19, 2005 04:15 PM
brent_G
Mar 19, 2004 04:15 PM
nuc79
Feb 1, 2004 08:21 PM
