Battery Light on again, =*(
Old Dec 5, 2002 | 06:29 PM
CdTriX's Avatar
Default Battery Light on again, =*(
Well... b4 my battery light would blink on and off ... changed teh alternator, then it's all fine, one day my tranny slips over revs to 6000 and then car flashes everything goes blank, and then stereo, gauge lights, and everything else is fine but the batterylight remains, it can't be the alternator because i can hear it whine, i dunno what it is.. should i just reset the ECU?
i don't know what to do!!!
btw! anyone know a white EF 4dr with black bumpers and a roll cage? saw one when my car messed up =*( in the greater toronto area?
[Modified by CdTriX, 3:30 AM 12/6/2002]
Old Dec 5, 2002 | 06:39 PM
the DR.'s Avatar
Default Re: Battery Light on again, =*( (CdTriX)
the alternator is not supposed to whine.. did you check your battery? try a load test and charging system test..
Old Dec 5, 2002 | 06:51 PM
CdTriX's Avatar
Default Re: Battery Light on again, =*( (CIVICtypeS)
the alternator whined when it was installed, i think it's not charging properly because the lights would get brighter.. but it fixed the battery light problem now i think it over charged or something and it's stays on now
EvlErn69's Avatar
New User
check all the wires are ground right and the battery is ground ummm... did you buy the alternator from where... if it is a kragen cheap... maybe return it and spend a lil more for a better one cuz the cheapie clunk out..... if not then maybe the main relay.. needs to be fixed...
Old Dec 5, 2002 | 06:54 PM
CdTriX's Avatar
Default Re: Battery Light on again, =*( (EvlErn69)
dad got it from wal-mart? for 60 bucks... brand new i think not sure
Old Dec 5, 2002 | 07:03 PM
EvlErn69's Avatar
New User
who installed it??? fuhh when did Wal-mart sell alternator's???? go check and see if the belt is tight and not loose
Old Dec 5, 2002 | 07:09 PM
CdTriX's Avatar
they do here in canada?
everything was fine untill now i'll check tomorrow, god damn it... i'm sooo mind boggled!
Old Dec 5, 2002 | 07:45 PM
chhuong's Avatar
okay if it whines, it may mean that the belt was too tight, and if the belt is too tight it will overload the bearing which in turn can burn out a diode, which will reduce the output of the alternator thus causing the battery light to come on!!
Just a thought!!
Old Dec 6, 2002 | 12:48 AM
CdTriX's Avatar
Default Re: Battery Light on again, =*( (chhuong)
anyone else have any idea y?
Old Dec 6, 2002 | 05:51 AM
Ham'ed Hatch
Guest
Posts: n/a
yeah the guy you're talking about is on honda-tech. don't know his name tho. it's this car i'm sure...
and what the **** is this about Wal-Marts being in Canada?! what're they doing there. i swear those damn mormons are taking over the world!!! jerks.
Old Dec 6, 2002 | 11:47 AM
CdTriX's Avatar
Default Re: Battery Light on again, =*( (Ham'ed Hatch)
do you know if he has another set of rims?
the one i saw had black GSR/LS mesh type rims
we drove by each other and gave the thumbs up
wal mart pretty much is taking over north america, it's the slave labour of the malaysian kids funding america!!!
well my dad took the car out and it died again, i'm guessing the alternator is kaputz!
Old Dec 6, 2002 | 11:40 PM
EvlErn69's Avatar
New User
car up the battary and see if it dies again... then it should be sure its the alt...
Old Dec 7, 2002 | 07:37 AM
Magick211's Avatar
I have a new altanator for sale it was only used for a month are so, casue i put in a ls motor. ill let it go cheap
Old Dec 7, 2002 | 10:39 AM
Hcivic88's Avatar
I think he means charge up the battery
put a volt meter on the battery while the car is running, you should be getting around 14V, if you're only getting like 12 or less, then its probably your alternator
Old Dec 7, 2002 | 01:48 PM
crx(gator)'s Avatar
wal-mart is in 26 countries now... nothing wrong with them...
Old Dec 7, 2002 | 11:05 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Battery Light on again, =*( (crxgator)
that's scary.
there's nothing wrong with wal-mart i guess (i shop there lots), but i don't like momos...they try to shove they're half-*** religion down your throat every chance they get.
i say bleh!
Old Dec 8, 2002 | 06:19 AM
DsMWookie's Avatar
Go to Autozone have them test your alternator and battery for starters....2nd if its whining its the bearings probably in the alternator....3rd make sure theirs enough tension on the belt for the alternator I did it once and just didn't put enough tension on it and it stayed on and cut the car off.... Good luck
Old Dec 8, 2002 | 07:03 AM
MNTuner's Avatar
See what the system charges at. If it is around 13-15 v your doin' great! Now perform a load test on your battery (crank the starter a couple time with the ignition un plugged or whatever.) If the battery dies after a couple seconds of cranking (literally 3-5 seconds) REPLACE THE DAMN THANG! Start the vehicle and let it warm up, then unhook the battery. If the car still runs your alternator is fine if it instantly dies you sir, have a bad altenator circuit.
legionbuck
Mar 31, 2013 04:51 AM
tyvtec23
10
Feb 10, 2012 11:22 AM
MDAnhorn
Dec 28, 2007 04:15 AM
siregcivic
Jun 22, 2006 11:15 PM
smash fascism
Dec 22, 2005 09:13 PM
