CV joints or clutch?
Old Dec 5, 2002 | 12:49 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default CV joints or clutch?
I have a 1991 accord 5spd with little to no modifications(intake, muffler, wheels).
it has 140000 miles on it and is still on the original clutch. Here is my delima, usually when I am making a turn onto a traffic-infested road I accelerate almost to the maximum capabilities of the car. occasionaly when I am doing this, something slips(i am almost certain it is not the tires) it only gets noticeable as it approaches the powerband. I know that my cv joints are starting to go because they pop when I corner. This slippage almost never happens on straight line acceleration. Ive even tried(please do not slap me too hard) driving straight and giving it gas while hitting the brakes(i would think that if the clutch was going out that that would cause it to slip) and still no slippage. Please help
Old Dec 5, 2002 | 12:57 PM
2000Accord5sp's Avatar
Default Re: CV joints or clutch? (tharptroy)
Sounds to me it's most likely the CV joints. If they're going out anyway, replace those first and see if it fixes the problem. I still don't get exaclty what you mean by 'slip' though...
Old Dec 6, 2002 | 03:56 AM
urbanlegend21's Avatar
New User
Default Re: CV joints or clutch? (2000Accord5sp)
clutch, your CV's will not slip, they will pop, vibrate, or just bust
Old Dec 6, 2002 | 06:14 AM
Stew Pidasso's Avatar
Default Re: CV joints or clutch? (urbanlegend21)
Yeah, if you've ever taken them apart, there is about no way for them to slip. My money is on the clutch too.
Old Dec 6, 2002 | 09:53 AM
cyrixvsp2's Avatar
Default Re: CV joints or clutch? (Stew Pidasso)
clutch....cv joints don't slip. my 85 accord did that when the clutch was going out.
Old Dec 6, 2002 | 09:30 PM
Bantam's Avatar
Default Re: CV joints or clutch? (cyrixvsp2)
Thanks for the input, does anyone suggest a brand of clutch to go with, I would be looking for mild racing, streetable clutch.(i hope that makes sense)
Preferably throw n some some links if possible
[Modified by tharptroy, 6:37 AM 12/7/2002]
Old Dec 8, 2002 | 07:23 AM
EuRoBrO's Avatar
ACT
Old Dec 8, 2002 | 07:07 PM
Bantam's Avatar
Default Re: CV joints or clutch? (EuRoBrO)
I have one final question. If I were planning to swap in an H22 would I be able to use the same clutch? if so, would it be better to go with 43% holding capacity over stock or 90%? also would my car be able to function properly with such an increase in holding power? if it helps, i think my car came stock with 125 hp(slow).
Old Dec 8, 2002 | 07:14 PM
smokin rubber's Avatar
clutches, flywheels, engines and transmissions are interchangable. So yes you can use the same clutch on the H22. The only problem with a stiffer clutch is in very low speed stop and go traffic.
David12
13
Oct 9, 2009 08:46 PM
SimplyTron
May 14, 2009 01:44 PM
ex_techniques206
Jun 23, 2005 11:25 AM
neopheus
Mar 13, 2005 10:20 PM
James
Feb 6, 2003 03:59 AM
