How to blow a dx motor...? any suggestions...
Old Dec 5, 2002 | 10:27 AM
b16_madman's Avatar
Default How to blow a dx motor...? any suggestions...
this needs to be w/out being obvious b/c my mom said she'll drop the money for a b16 as soon as my motor goes...it already has a blown head gasket...and for some reason the cylinder closest to the timing belt its spark plug wire wont go down all the way...
---how long will it last @ redline?
Old Dec 5, 2002 | 10:31 AM
Bugermass's Avatar
Default Re: How to blow a dx motor...? any suggestions... (B16_madman)
advance your distributor all the way the run it all out like that on regular unleaded, once it blows you can turn the distributor back..
Old Dec 5, 2002 | 10:39 AM
4potnick's Avatar
lots of nitrous. you will have fun with it to. couple runs and then kaboom.
Old Dec 5, 2002 | 10:41 AM
THCRXsi's Avatar
Default Re: How to blow a dx motor...? any suggestions... (4potnick)
go from third gear red-line and slam it into second and it should by-pass the revlimter
civbeater90's Avatar
um if your serious-i would drain all oil and antifreeze!
Old Dec 5, 2002 | 10:52 AM
ricodemus's Avatar
Default Re: How to blow a dx motor...? any suggestions... (civbeater90)
take off the air box so air flows freely through the throttle body. I always wanted to see what that would do. but yeah, doing some third gear redline- 2nd shifts should do.
Old Dec 5, 2002 | 10:53 AM
Hcivic88's Avatar
but whats the fun in that> I say redline 3rd and slam it back into second, do that a couple times and she'll go
Old Dec 5, 2002 | 10:55 AM
Hondasaurs's Avatar
Default Re: How to blow a dx motor...? any suggestions... (Hcivic88)
Fill the tank up with diesel and act like you don't know whats wrong with it.
Old Dec 5, 2002 | 10:56 AM
PhatOptimo's Avatar
Strap a bomb to it. KABOOM fo sho.
Old Dec 5, 2002 | 11:03 AM
shortyz's Avatar
Default Re: How to blow a dx motor...? any suggestions... (Phat_Optimo)
fill it up with diesel and dump a quart of oil in the gas tank.
then put a brick on the gas pedal and see how much of the block u can smoke out.
Old Dec 5, 2002 | 11:08 AM
EF_LSVtec's Avatar
When did your Mom say this? i'd wait a few more months maybe or else she'll suspect somethings up...the redline thing would blow up the head gasket and she may just opt to get it fixed...draining the oil would do it...it would be a slow painfull death though...Make sure that you have roadside assistance too, hehe.
Old Dec 5, 2002 | 11:10 AM
Hcivic88's Avatar
Default Re: How to blow a dx motor...? any suggestions... (EF_LSVtec)
very good point, lol. and try not to make it too close to your house either cause it would be too obvious. and yea like EF_LSVtec said - if she just told u recently, wait a little while, but still drive it hard while you're waiting
Old Dec 5, 2002 | 11:18 AM
ex voto's Avatar
There's only one option...
Rally Civic!
Old Dec 5, 2002 | 11:21 AM
eur0's Avatar
wouldnt it make more sense to just sell the motor for a few bucks? just tell her its about to blow and you can make a little more profit from it That or just beat the **** out of your engine or slice your timing belt and bend some stuff heh
Blaze45's Avatar
Brrraaaap!
Default Re: How to blow a dx motor...? any suggestions... (ex voto)
Do a cheap turbo system like buy the compressor and down pipe and oil and charge line and run 15psi. Your car will MOVE. Expect some serious detonation = engine blowing.
Old Dec 5, 2002 | 11:22 AM
Charlie Moua's Avatar
Default Re: How to blow a dx motor...? any suggestions... (THCRXsi)
fastest way to do it.
**** spending 1hour hooking up the NoS just to blow it up. to time consuming
Old Dec 5, 2002 | 11:23 AM
Default Re: How to blow a dx motor...? any suggestions... (ZC_CRX)
that would be the most innosecnt "get away free" way to do it.
Old Dec 5, 2002 | 11:30 AM
slowman's Avatar
I took way too long
Default Re: How to blow a dx motor...? any suggestions... (Charlie Moua)
ouch! the thought of draining oil of the engine and driving it makes me cringggge!! but that would mess it all up!
Old Dec 5, 2002 | 11:44 AM
BlackCRX's Avatar
Default Re: How to blow a dx motor...? any suggestions... (slowmanEF)
find an empty parting lot with a few friends
get a brick and lay it on the gas then run away
start a pool with your friends to see how long it will last
that way you can make some money while blowing your engine
Old Dec 5, 2002 | 11:55 AM
JoshDM's Avatar
do not put diesel fuel in it you'll corrupt all your fuel lines and blow the fuel pump
Old Dec 5, 2002 | 12:00 PM
nak41.5LVtec's Avatar
1. Drain oil
2.Take air filter off spray one can of starting fluid into intake
3. Leave hood <U>open</U> this is very important( so you can watch)
4.start car
**You will hear your ride let out a roar like you have never heard before**
I did this with my 16v SOHC and the motor completly seized.
now taking care of a JDM 1.5L SOHC Vtec in 93 Civic Dx
**OH YEAH FOR GOD SAKES BE CAREFULL**
shortyz's Avatar
Default Re: How to blow a dx motor...? any suggestions... (JoshDM)
blackcrx
hahahhahaahhahah
thats a good one.
Old Dec 5, 2002 | 01:37 PM
Blue_Si03's Avatar
Default Re: How to blow a dx motor...? any suggestions... (shortyz)
I used a 55 shot of n2o and I blew it pretty good. BTW, I blew it so that I can get money for a better engine also, lol.
Old Dec 5, 2002 | 02:14 PM
USDM 4G VTEC's Avatar
dont u even think abou t putting **** on ur tank!!!! that will mess anc clog the fuel pump and the lines... u dont wanna do that....
if u really wanna **** it on a few seconds , do the 3rd redline thing and slap it into seocnd... be careful bc u prob will be going aroun 80 mph and WEAR A SEATBELT!!!
if i were u , i will drain the oil ,. and put some water base **** into the intake manifold... and add some BB's also!!!!!
and run it like u have never done it !!!! i will hydro lock, seize and blew the engine in a nice beautiful way!
Old Dec 5, 2002 | 02:33 PM
SC0TT's Avatar
Default Re: How to blow a dx motor...? any suggestions... (JDM EF9)
Put some popcorn seeds in the intake, maybe youll have some popcorn coming out the exhaust...hahaha kidding
Just drain the oil or 3rd to 2nd it....
