D16A6 Turbo Setup, Tried Searches but nothing came up.
I have a 1991 crx si, i bought a Drag manifold (Pic Below)
and im gonna need a T3 Turbo, im also going to purchase an intercooler either custom or a junkyard thing. doesnt matter..
what im wondering is what else would i need like Fuel / Ecu wise.. i know i need exhaust, pipes, blow off valve but as for Fuel Delivery and Ecu stuff what should i get i only want to run 6 to 8lbs on this motor till it dies out. the car has a new clutch.
After it dies i will either get a b16a swap or sohc vtec.
[Modified by Sirex, 12:28 PM 12/5/2002]
Lots of options here. Filetofit circuit...SMC...FMU....AFC...zdyne...hondata...ems ..motec in order of cost. Lots of archived info if you search thru it all.
How much money do you want to spend? Get some used DSM parts if you want to go cheap.
lots of info below:
My site in the sig.
http://www.thedropshop.tv
http://www.homemadeturbo.com
Maximum Boost, by Corky Bell at Barnes and Noble.
Randy
My site in the sig.
Randy
for 6 to 7 lbs, you could copy a stage II revhard system (i believe):
-t3
-turbonetics deltagate wastegate
-intercooler
-blow-off valve
-cast manifold
-msd in-line fuel pump
-vortech FMU
-you can use stock injectors if you run low boost 6-8psi
-you'll need to run check valves or a missing link because the stock map sensor doesn't like positive pressure w/ a stock ECU.
w/ this set-up, I ran a 14.7 @ 97mph w/ 8psi..
-t3
-intercooler
-blow-off valve
-cast manifold
-vortech FMU
If zip came up with SMC before I bought my Zdyne, that would be on my car now.
I run the dsm and Zdyne.
You might want to lurk here: http://crx.honda-perf.org/forum/index.shtml
There are a few guys working on a OBD-0 Zdyne for free. They call it the Ghetto-Dyne. It is in beta testing right now!! They have another website, but I can't find it.
Randy
Randy
