Changing gears in LS S1 trans
Old Dec 5, 2002 | 08:18 AM
racerxadam's Avatar
Default Changing gears in LS S1 trans
So I'm pretty sure I got screwed when I bought my swap and ended up recieving an S1 trans from an LS instead of the S1 from a JDM car. I haven't taken the trans apart yet to count teeth but I would like to know what my options are as far as changing the gearset in this trans. I would like the gearing to be closer to the 92-93 GSR gearing but I would like to keep my fifth gear ratio for highway cruising.
Can I use the gears from the 92-93 GSR trans? If not what are my other options? Where can I find more about what gears I can use?
[Modified by racerxadam, 10:47 PM 12/5/2002]
Old Dec 5, 2002 | 06:47 PM
racerxadam's Avatar
Default Re: Changing gears in LS S1 trans (racerxadam)
up
Old Dec 5, 2002 | 07:54 PM
chhuong's Avatar
I'm not 100% sure but i'm pretty sure that if you get gears from a jdm s1 they will swap over!!
Old Dec 6, 2002 | 05:23 AM
racerxadam's Avatar
Default Re: Changing gears in LS S1 trans (chhuong)
I'd rather get a usdm gearset. Anybody else?
Old Dec 7, 2002 | 07:52 PM
Jaker's Avatar
It all depends what year the S1 is. If its 90-91, then you are pretty much fubared. If its 92-93 (and I'm not even sure there were any LS S1s from 92-93), then you can swap over the parts.
Old Dec 7, 2002 | 07:56 PM
Type X's Avatar
hmmm
Old Dec 7, 2002 | 09:31 PM
Jeff C's Avatar
Default Re: Changing gears in LS S1 trans (Jaker)
What makes you think that you got screwed?
92-93 LS and GSR have the YS1 code.
Old Dec 7, 2002 | 10:08 PM
racerxadam's Avatar
Default Re: Changing gears in LS S1 trans (Jeff C)
I'm trapping over 102 mph in the 1/4 mile and I'm only just needing to shift into 4th gear to as I'm passing through the finish.
Old Dec 7, 2002 | 10:52 PM
Malgerus's Avatar
My bro shifts into 4th near the end of the quarter with his JDM S1. He's going 96 mph.
Old Dec 7, 2002 | 10:53 PM
racerxadam's Avatar
How do you tell which trans is which? 90-91 v. 92-93?
Old Dec 7, 2002 | 10:58 PM
racerxadam's Avatar
Default Re: Changing gears in LS S1 trans (Mr. S)
according to this gear ratio calculator with a jdm S1 trans, using 24 inch drag radials and an 8500 rpm redline my maximum speed would still be 97.4 mph in third gear. I have trapped 104 mph and there is no way that i picked up 9 mph in the last 50 ft of the 1/4 mile.
Dirty_SL8
Transmission & Drivetrain
Apr 11, 2011 08:23 AM
killerpenguin21
Aug 29, 2007 06:23 PM
92JDMSiR
Jan 16, 2004 06:26 PM
