what do you use to clean the CLOTH part of ITR seats
on the cloth i vacuum real good then use a damp cloth or rag and press into the seat section by section......let dry.......vacuum....repeat if necessary
on the suede or whatever u want to call it, i use my timberland kit .......spray ,scrub, spray, brush, then spray again....i like the way it smells....smells like when you open a box of new sneakers
try a search someone posted a link on how to clean what ever the suede knock off stuff is in our cars i think its called alcana or something like that but any ways he posted a link in somones thread to a site that tells how to clean it perfectly.
- Extensive soiling or spots may require the entire cover to be washed.
- Removable covers: Removable Alcantara® covers are very easy to clean, and can be safely washed with water in the washing machine set at 30º. To maintain the original freshness of the fabric, brush it with a soft brush once it has been washed. If the upholstery is fitted with Velcro, cover each piece with a Velcro cover.
- Non-removable covers: Non-removable Alcantara® covers can be cleaned with soap and water. Avoid using solvents (particularly perchloroethyene and trichlorethylene) and contact with steam cleaners. The use of "spray extraction" upholstery cleaners is acceptable at low temperatures."
fro those who are lazy...
Ibuprofen
Jan 3, 2002 01:02 PM
