95 ex auto vtec motor into 93 accord lx 5 speed????????
Old Dec 4, 2002 | 03:41 PM
Acura_I-RS's Avatar
Default 95 ex auto vtec motor into 93 accord lx 5 speed????????
ok, a kid i know has a motor out of a 95 accord exits an f22b i think, the sohc vtec one, and my motor has very high miles, and doesnt run that great anymore, he wants 600 for the motor and auto tranny, but i dont want the tranny, where can i sell the tranny?and how much is it worth? it has 58k miles on it, but my car is a 5 speed, and also will this motor work out ok in my 93 accord lx??are there any obstacles to overcome doing the install?
im not doing this for performance either, it is just my beater i drive to and from work everyday
Old Dec 4, 2002 | 03:47 PM
carolinaACCORD's Avatar
Default Re: 95 ex auto vtec motor into 93 accord lx 5 speed???????? (Acura_I-RS)
sure, itll work. just make sure you get the ecu for it, too.
installation should be farely simple.
you could probably sell the tranny for what you are buying the whole setup for, no problem. the f22 trannies usually will run you anywhere from $800-$1200, sometimes as low as $550.
Old Dec 4, 2002 | 05:05 PM
Acura_I-RS's Avatar
Default Re: 95 ex auto vtec motor into 93 accord lx 5 speed???????? (carolinaACCORD)
any idea where i could get rid of the tranny?
and is the wiring different between an auto and manual tranny??
he has the wiring harness and ecu for the ex motor, but i wanna make sure it will all work 1st
Old Dec 4, 2002 | 05:18 PM
you could probably sell the tranny to a salvage yard or out of a parts magazine, just about anywhere.
im pretty sure the 95's auto ecu's had a seperate transmission computer, so you may just be able to use the engine computer and itll work.but im not 100% sure.
PLEASE someone correct me if im wrong, i dont wanna give any wrong info.
Old Dec 6, 2002 | 12:23 PM
Acura_I-RS's Avatar
anyone else know about this?????????????
Old Dec 7, 2002 | 12:47 PM
slow02ss camaro's Avatar
ohh and just so you know....if you use that motor, you must use all its accesories...**** like the alternator, a/c, p/s will only work with its own motor...you can't interchange parts from a 93 or earlier(i think f22b1) onto a 94-97 motor(i think f22b2). I tried to put a 94 motor in a 92 and the accesories off the 92 would not bolt up to the 94 motor so I had to buy **** off a 94 and make it work.
Old Dec 7, 2002 | 12:48 PM
Default Re: 95 ex auto vtec motor into 93 accord lx 5 speed???????? (slow94accord)
It may have just been the brackets or sumthing...this was ahile back so I forget everything. But I know you'll have to play around with the different brackets and accesories to see which works and doesn't.
Old Dec 7, 2002 | 12:51 PM
ArchAngel Sabastian's Avatar
New User
the motor your getting if from a 95 ec is a f22b1 i think you can use the auto engine harness but you might want to see if you can get a hold of a manual one to be sure the auto one has i think two extra plugs on it im not sure if you can just chill them also you will need the 5spd ecu to do the swap. it should be pretty easy straight forward use all f22b1 mounts,
uh what manual tranny are you going to use?
https://honda-tech.com/zerothread?id=352461
depending on how that thread progresses it may help you
[Modified by ArchAngel Sabastian, 3:52 PM 12/7/2002]
[Modified by ArchAngel Sabastian, 3:53 PM 12/7/2002]
GReddy SI
Nov 20, 2004 12:15 PM
f22suzuka
Dec 26, 2003 05:09 AM
Acura_I-RS
Sep 20, 2002 05:48 AM
Acura_I-RS
Aug 27, 2002 03:52 PM
Acura_I-RS
Aug 13, 2002 02:37 PM
