who did: EF w/ sohc v-tec motor...
Old Dec 4, 2002 | 11:53 AM
TypRice's Avatar
Default who did: EF w/ sohc v-tec motor...
and is using the stock trans!
Old Dec 4, 2002 | 12:02 PM
Speedfreak's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (TypRice)
I have a 90 civic dx with single vtec
I didnt use the stock dx tranny I use an si tranny from a 4 gen
Old Dec 4, 2002 | 12:19 PM
TypRice's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (Speedfreak)
ok great what ecu are you using?
Old Dec 4, 2002 | 12:43 PM
Blue_Si03's Avatar
I have a JDM D15B with DX tranny using MSD RPM Switch (4,800) and PM6 Ecu. I have a PG7 Ecu but haven't used it yet.
Old Dec 4, 2002 | 02:00 PM
vtecrx's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (CRXracer89)
89 crx dx, d16z6, dx tranny(for now) converted to OBD1 with a P28
Old Dec 4, 2002 | 02:10 PM
Malgerus's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (vtecrx)
I did it...
96 D16Y8 with P28 ECU... Ran REALLY fast... kept up with many B18's.
Old Dec 4, 2002 | 02:43 PM
TypRice's Avatar
how did you get the speed sensor to work?
Old Dec 4, 2002 | 03:36 PM
vtecrx's Avatar
all I did was use my conversion harness and it plugged and played. chack my sig
Andy
Old Dec 4, 2002 | 05:05 PM
91sihtch's Avatar
i just put a 94 del sol sohc vtec motor in my 91 si hatch.i used the si trans and had a conversion harness made to connect to a p28 ecu.evrything works great.
Old Dec 4, 2002 | 05:40 PM
USDM 4G VTEC's Avatar
look at my signature
i had a SI tranny but already broke it.. sitting on my shed until i can rebuild it and put it back on....
Old Dec 4, 2002 | 06:35 PM
Hayasa15's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (JDM EF9)
I am putting in a 92 D16Z6 w/ a 91 si tranny, into a 90 std civic hatch. I am going to run a Hondata w/ a P28 and a conversion harness to convert my car to OBD1.
Old Dec 4, 2002 | 06:48 PM
Art T. Fish L.'s Avatar
Default Re: who did: EF w/ sohc v-tec motor... (Hayasa15)
Mine is in the works, I'm waiting for the shop to finish building my tranny.
Old Dec 5, 2002 | 07:26 PM
Mefain's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (MiniSiCRX)
got an 88 CRX DX...D16Y8 swap...i used my 88 Si tranny...only thing that i had to change over w. the tranny's was the flywheel...all d-series trannys will bolt to a d-series motor...ECU is a 89 Integra...Vtec is switched on w. MSD RPM Switch at 4800...car pulls hard during VTEC...it needs adjustments though
Old Dec 6, 2002 | 08:04 AM
TypRice's Avatar
Default Re: who did: EF w/ sohc v-tec motor... (NjoySleepn)
ok i lied...i had a problem with the speed sensor it self...at the vss. the speed isnt going in to the trans...what years are ur trans' and which sensor r yall using?
Old Dec 6, 2002 | 08:52 AM
TypRice's Avatar
i had problem with the vss. going in to the trans.
Old Dec 6, 2002 | 09:55 AM
IamVtec's Avatar
What yr SI Distributor cap will bolt right up to the Z6 without modification? is it possible?
Old Dec 6, 2002 | 11:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: who did: EF w/ sohc v-tec motor... (crx dragga)
92 D16Z6 in my 89 CRX Si using a PR3 JDM B16A ecu(knock sensor removed), 89 Si tranny with 92 Si flywheel and clutch kit,and a field's vtec controller. runs GRRReat!!
Old Dec 6, 2002 | 11:44 AM
JOEY F.'s Avatar
Default Re: who did: EF w/ sohc v-tec motor... (yebabee)
I got a d16z6 long block in my 91 hatch...
Just bolt ons with a zdyne one wire vtec conversion. WAY better than the MSD activated vtec method, fuelmaps set and no problems during daily driving. I guess just read the sig for more info....
[Modified by JOEY F., 3:47 PM 12/6/2002]
NorcalHB94
Mar 28, 2005 10:16 AM
CRseXy
11
Dec 30, 2004 11:29 AM
The DX Rex
Jul 10, 2004 08:29 AM
ek9 ferio
Jul 12, 2003 12:20 PM
zcivicz
Nov 22, 2002 10:39 PM
