how to ground coil for compression test?
need to run a compression test before i change the timing belt, would be nice to see what kind of shape the rings/headgasket are in as that would be the best time to pull the head. thanks.
You just need to disconnect the 2P connector from the distributor. That's the round 2 wire one. Then do the compression test.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
