Stainless o-ring and Cometic head gasket compatible?
Old Dec 4, 2002 | 07:00 AM
2point6's Avatar
Default Stainless o-ring and Cometic head gasket compatible?
Like the title says, can a Cometic gasket be used with a stainless o-ring instead of a copper ring? I have been having minor head gasket leaks with my copper SCE head gasket/stainless o-ring set-up. I was wondering if the tougher (harder) materials will work together and provide a better seal rather than the softer (maleable) copper. Anyway, does anybody run this type of set up and how does it work for you?
Old Dec 4, 2002 | 10:25 AM
2point6's Avatar
Default Re: Stainless o-ring and Cometic head gasket compatible? (2point6)
Old Dec 4, 2002 | 03:12 PM
earl's Avatar
You can use the Cometic MLS gasket but not the HP (it has an o-ring already in it). No problem that it is stainless rather than copper as long as the o-ring does not stick out more than half the thickness of the gasket.
Old Dec 4, 2002 | 07:08 PM
2point6's Avatar
Default Re: Stainless o-ring and Cometic head gasket compatible? (earl)
Thankyou for the reply.
Old Dec 6, 2002 | 07:43 PM
ninesecteg's Avatar
use a stock head gasket!!! cometics are garbage!
Old Dec 6, 2002 | 09:23 PM
earl's Avatar
Default Re: Stainless o-ring and Cometic head gasket compatible? (ninesecteg)
Please give your reasons behind this statement, Nick. BTW, love your car!
I have to say I disagree with you because I had to pull our head before a race and did not have a spare. I reused the Cometic and boosted 26lbs with no problems. Became a believer after that.
[Modified by earl, 8:23 AM 12/7/2002]
drewlee
Aug 9, 2004 12:00 PM
therealnapster
Sep 10, 2001 01:32 PM
therealnapster
Sep 9, 2001 08:07 PM
