quick rear wing question
Old Dec 4, 2002 | 01:15 AM
Phoenix_ITR's Avatar
Default quick rear wing question
just a real quick question:
is there any adhesive or sealant used to hold the rear wing on? i was thinking about removing it just for kicks but i don't want to have to mess around with adhesive remover. thanks in advance.
-tony
Old Dec 4, 2002 | 01:36 AM
yellow blur's Avatar
Default Re: quick rear wing question (delinquent)
The stock wing is held on by 4 bolts AND double sided tape/adhesive. Going to kragen/pepboys and buying a can of 3M adhesive remover isn't too much trouble.
You're going to have more fun cutting through that adhesive than using some liquid to remove it off afterwards.
[Modified by yellow blur, 2:37 AM 12/4/2002]
Old Dec 4, 2002 | 01:40 AM
Default Re: quick rear wing question (yellow blur)
thanks for the info.
to re-install the wing, would you recommend just using 3M double-sided tape? or is there some other product better suited for the job? thanks!
-tony
Old Dec 4, 2002 | 01:43 AM
3M double sided tape would do just fine. I actually just slapped it back on w/ whatever was left on the wing. The deck lid seems to be fine. It's up to you if you want to use the tape or not. I guess use it to protect the deck lid from any damage.
Old Dec 4, 2002 | 01:44 AM
great.
i figured that there would be some form of adhesive just to keep water and whatnot from leaking through the bolt-holes. i was hoping that i could just take the wing off to see how the car looked but it seems like it might be more trouble than it's actually worth. thanks for your help.
-tony
Old Dec 4, 2002 | 01:45 AM
uNF$@#!'s Avatar
pfft. someone removed my "y" answer. .
i guess a y or n answer isnt good enough for the mods now.
[Modified by Soup ****, 5:46 AM 12/4/2002]
Old Dec 5, 2002 | 08:52 AM
AccrdATK's Avatar
New User
great.
-tony
dont do it!!! i did took off mind for the same reason you want to take off yorus...and now i have to spend a couple bucks (xmas presents are killing me!!) to buy adhesive to put it back on...but i have to admit tho... around so cal... i havent gotten any looks at cops since it was off... which is good in a way... but it looks plain.. im going to put it back on soon... when i find time
Old Dec 5, 2002 | 10:34 AM
Hooch'n's Avatar
Default Re: quick rear wing question (CoreysTypeR)
Seems a lot of people take the wing off.......then put it back on. Seems as if their is a reason the car has the wing in the first place.
Old Dec 5, 2002 | 11:03 AM
Q-OnE's Avatar
Default Re: quick rear wing question (Hooch at 8400-RPM)
everybody gets bored.
Old Dec 5, 2002 | 05:53 PM
Default Re: quick rear wing question (FeeL's gs-R)
exactly!
Old Dec 5, 2002 | 07:53 PM
1GreyTeg's Avatar
I took it off and put it back on for track days... Funny enough though, the last time I put it back on the look grew on me again and made me think of permenantly affixing it again.
Does it make a difference? Ask George.
I used Afta adhesive reomover and used plugs from a civic strut cap for the holes. I also got my hands on a set of gaskets for the wing from Wings west but, you can check some of my older posts for all that info.
I will be reinstalling it again as I get more and more active with track events as opposed to only autocross. You don't need the wing, and especially for autocross.
Good luck,
A.
QuickStyle
Oct 31, 2009 10:36 AM
AcuraRacer112
11
Oct 10, 2002 09:28 AM
JDM_Type-R
Jun 19, 2002 03:29 PM
ActiveAero
Mar 7, 2002 08:31 PM
threatcon13
Nov 11, 2001 02:05 PM
