Will solid rear axle (like MMR) tuck my "skinnies"??
The Bogart rears "skinnies" that I have stick out, ALOT. They stick out to the point of rubbing on launches.
Besides the obvious weight advantage of a rear solid axle (like MMR), will the axle also bring the rims closer to the wheel well
here is a pic of them on my car:
also comes with KY for the 4500 you pay withgout wheels
yea the mmr will bring it in and usues stock mounting points. like a 80 lb savings i think...somewhere round there.
they also sell staging brakes. they arent that expensive.
I ordered my MMR usa rear solid axle about 3 months ago. I still haven't received it yet, mine is for sale sincee I am no longer making a street car. They said I should be receiving it this week. WHen you order it they tell you 2-3weeks yoiur happy then wait months and get screwed but, mine should be here this week and its for sale 92-95 civic hatchback brand new. same one on there webpages. I backed out the race car project. i have a 88-91 street car now crx.
i just received my mb product solid rear axle yesterday(same as mmr) only took about 2 weeks from mb motorsports. havnt installed it yet though. was somthing like 1350 for the solid rear and then 140 or so for the staging brake
yeah that is correct you cannot in a street car class all motor you can. other classes you can but you have to keep the rear sub frame like in hot rod and idrc. but there is no point if u have to keep the sub frame.
the solid rear included wilwood light duty disc brakes and calipers, pads, and it just bolts rite in to your factory location, subframe needs to be removed. only thing it didnt come with is the brake lines. i just sent it to get powdercoated, but as soon as i get it back, ill try to post installed pics.
im most curious to see what the stock brake components weigh
Him, the loudest? Have you seen any and every car in the all motor class? Or how about when I almost got deafened by Team Altech's Turbo beast when he was launching this summer? That pops that thing make are retarded....
Clayton
Clayton
Clayton
Clayton
I was asking more from a curiousity standpoint.
I'm building a drag-only car this winter and will be using those skinnies, and it was something that stuck in my mind
here is a shitty pic with the rear jacked with Skunk2 900lb springs:
[Modified by allmotorhonda, 10:16 PM 12/13/2002]
i just installed mine today and it brings the wheels in. looks much better than it used to and definatly save alot of weight. i just need to get lug nuts for my bogarts, the old ones didnt thread on for some reason. ill try to post pics
moly lube
