.help fast fast please???
i was driving dis morning and my car's engine check light turned on. i was lyk no. then my d4 light started to blink. if you have not notice so far i got a SS, but my tranny was fixed by honda at 39,000 miles. and now i got 49,875 don't ask i was the second owner. the first owner was my uncles. well back to the story, i went home and then i check the oil sorry i'm a noobie. the oil was black and smelled lyk gas mixed wit oil but smelled more lyk gas. i mean the car drove fine all the way home. no diffrent at all. When i got home i poured more oil in i use mobile1 synthic. I heard it was really good to use so i use it, but do you guy's think its because i have a intake and no exhuast or header that makes the oil that black. even before i was suppose to change my oil it was already low and it was really dirty. thank you guy'z for all the help need quick help. also i wanted to know if the engine check light is on how do i turn it off myself i heard to reset the ecu. i was thinking if i pulled the fuse for it would that work. also if you can could you tell me how to reset the ecu. thank you guy'z i was so scared this morning i was lyk its my second car and i never had that happen to me before.
If your oil wasn't low you shouldn't have added any.
If your CEL and D4 light are blinking it is most likely a tranny problem. Don't just reset the light, take it to your dealer to have it looked at.
no the oil was low, and i can't bring it to the dealer i have to put back the stock intake first. also after i had turned off the car, and turned it back on. the d4 stop blinking but the cel was still on. does that mean it was not the tranny? nothing went wrong on the car, i could still shift through all 4 gears and they would shift fine. no lag no hard shift nothing at all. but when i got home i checked the oil an it was dark. lyk really dark. i was just wonding if it was that? also if it was the oil after i change it i still have to reset the ecu to get the light off right?
If the CEL comes on AND the D4 blinks, then the TCM is reporting that a transmission code has been thrown. DO NOT RESET. The whole point of the CEL is to tell you something. It is not merely an annoying light that comes on that has to be made to go away. If you do not have a datalogger or a code scanner, then take your car to a dealer and have the car checked out.
[Modified by sharkcohen, 2:05 AM 12/5/2002]
ok but should i put back the intake first before i bring it to the dealership, because i'm scared that they might take the warrentie off.
how do i get the code i can't don't know how.
ok i will try it today. just leave the paper clip their and turn on the car, but don't start it i will give you guys the code asap. after i get out of school.
the check engine light went on blinked 7 times, and the d4 blinked 4 long and 5 short. what does that mean?? thanks and could you guys tell me asap. thank you.
If you decide to take it back to the dealership, then put your stock intake back on before going there. Anyways, heres the site to see how to jump your cel.. Go to http://www.hondaprelude.to/main_checkengine.html
i don't really know,the engine check light it did not blink as fast as the d4 when the d4 was blinking fast. but the d4 blinked 4 long and 5 short. if you don't beleive me i do it again just to make sure?
[Modified by LuderX, 12:49 AM 12/5/2002]
Ok, the engine code you are throwing is 70, which just means that there is a transmission problem and it is referring you to the tranny code flashed by the D4 light. However, there is no tranny code 45, I don't know what to tell you there.
thanks for everything guy's we will see what happens. i'm bring the car into honda tom. for the check up. $70 for them just to test it. and then they see if they would pay 4 it. cuz i have a 2001 prelude and they serviced my tranny at 39,000 miles. cuz i heard honda extend the warrentie for trannie to 100,000 now. cuz of all that had happened.
o yea i reinstalled the intake. it took to long. hurt my back darn it. hahah
but its cool at least i know its a tranny problem. could i tell them i brought the car to a place and they ran a test and said its a trannie problem???
also would honda put a manual trannie now, since i got mine broke twice already. i hate this dam SS thing its so crappy. i don't drive hard on it i don't go past 4000rpm for daily drive and the tranny is messing up on me.
