time to change brake pads, which one should i get?
Old Dec 3, 2002 | 05:05 PM
Tiwe's Avatar
Default time to change brake pads, which one should i get?
my stock pad have all worn out and its time for a brake pad change, which ones do u guys suggest? my car is daily driven street car.. .going to track a few times next year (so like 70%street 30%track)...and also which brake fluid should i use? and aslo what are brake lines for? should i change my brake lines?(if so which ones to get?)
thanks in advance
Old Dec 3, 2002 | 05:06 PM
Rob :190:'s Avatar
Default Re: time to change brake pads, which one should i get? (Tiwe)
talk to andi at http://www.cobaltfriction.com
Old Dec 3, 2002 | 05:09 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: time to change brake pads, which one should i get? (Rob :190:)
Old Dec 3, 2002 | 05:22 PM
spoon_ek9's Avatar
Old Dec 3, 2002 | 05:25 PM
disordeR's Avatar
Default Re: time to change brake pads, which one should i get? (spoon_ek9)
Old Dec 3, 2002 | 05:27 PM
Tiwe's Avatar
Default Re: time to change brake pads, which one should i get? (disordeR)
uhh is Andi some brake god or do u guys all work for him hehe
Old Dec 3, 2002 | 05:28 PM
yoshi234's Avatar
I shoot brides
andie will most likely recommend Axxis Ultimate pads (which I use for street ) Best to just change pads for track events (maybe one of cobalts new pads). Brake fluid is again, one of Cobalts new products.
I'm assuming you're asking about SS brake lines. Not really needed for the type of driving you described, but it's cheap so that's optional. Helps keeps the brake pedal firm since it won't expand when the fluid gets hot at track events.
yshi - who needs to stop by stoptech and pick up some new brake pads
Old Dec 3, 2002 | 05:33 PM
Asahi's Avatar
And tell him you are an ITRCA member. We get 10% of Axxis Ultimate sales from members bewteen now and the expo. (THis assumes you get the Axxis )
If you arem't an ITRCA member sign up.
Old Dec 3, 2002 | 05:40 PM
nEoMuGen's Avatar
Default Re: time to change brake pads, which one should i get? (Asahi)
I never had experiences with the Axxis...but I used to run Porterfield R4-S on street and Autox and love every single day of using it. Now I have stock pads, it just felt so mushy!
I also ran Endless CCX...they are not much noticeable from stock when you first drove it until it brokes in. However, not much of a strong initial bite compare to the R4-S, they do withstand much better in high temperture. Ideal for weekend cruise car and track days. I wouldn't run them everyday on the street since they are so expensive.
[Modified by nEoMuGen, 10:38 PM 12/3/2002]
Old Dec 3, 2002 | 05:49 PM
disordeR's Avatar
Default Re: time to change brake pads, which one should i get? (nEoMuGen)
well i'll give a little review on what i have right now.
I have carbotech P+'s right now, only in the front. A little mix up with the rears.. and got them late. Since it's fall/winter now, i have no need to install the rears. Anyhow, with just the fronts in the car brakes noticeably better. In a 6 session track day and each session lasting 20 minutes, i had 0 fade with these pads. Very sure footed braking and good bite. The brake pedal was noticeably stiffer during braking...
only gripe, they squeel quite a bit. not a lot, but they squeel. they also dust quite a bite more than stock as well, however the it's non-corrosive.
overall, good track pad for a fairly good price.
Old Dec 3, 2002 | 05:51 PM
Tiwe's Avatar
Default Re: time to change brake pads, which one should i get? (yoshi234)
.....SS brake lines. ....
ok what dose SS stand for? Stainless steel? and what brand should i get for the brake line? oh ya how come none of u guys suggested Endless pads? i'm not some JDM ***** but i thought they make really good pads
[Modified by Tiwe, 2:52 AM 12/4/2002]
Old Dec 3, 2002 | 06:00 PM
Art Vandeleigh's Avatar
what material are these made of?? how are they on the rotors??
Old Dec 3, 2002 | 06:11 PM
disordeR's Avatar
Default Re: time to change brake pads, which one should i get? (Art Vandeleigh)
They are supposed to be rotor friendly. Material? check their site..
http://www.carbotecheng.com
Old Dec 3, 2002 | 06:13 PM
Jack Black's Avatar
Yes, SS means Stainless Steel.
Your original question was "what are brake lines for?" The stainless steel lines you always hear about replace the rubber hoses that go between the calipers and the steel tubes that run the rest of the way back to the master cylinder. The "stainless steel" lines are actually rubber hoses with a woven stainless steel covering over them. The woven covering provides a number of benefits, but probably the most important benefit for track use is that it prevents the rubber hose from expanding when it heats up from heavy brake usage. This keeps the pedal firmer and retains braking power.
SS lines are not a must-have for HPDE (track day) use. Upgraded pads and brake fluid are more important. But they seemed like a good enough idea that I went ahead and swapped them in when i first replaced the stock brake fluid with higher performance fluid. I ordered mine from Comptech, but they sent me Goodridge lines. From what I hear, Goodridge is good quality, and most places that sell SS lines sell them.
I don't know anything about Endless pads. I'm currently using Porterfield R4-S, and they're fine for my use (mostly street, with occasional autocross and HPDE). I'll probably switch to the Axxis Ultimates when these wear out because they're in the same performance category, I get a discount, and I can get them from Andie who is local to me.
Hope this helps.
Old Dec 3, 2002 | 06:23 PM
Jack Black's Avatar
Oh yeah, you can also try searching the "Archived Topics" in the "Integra Type-R" and "Road Racing/Autocross" forums for "brake". You'll get a ton of results, but sift through them a little bit and you'll also get a ton of useful information.
Have fun!
Old Dec 3, 2002 | 06:47 PM
Dropspeed's Avatar
Default Re: time to change brake pads, which one should i get? (itr01-0851)
I have run Porterfield RS4-s on on the street and really like the pad, Very little brake dust, almost no noise, they bite well when cold and have lasted fairly long compared to stock.
I switch to Hawk blues on the front for track days.
I was very happy with the results of just switching to a nice pad, adding stainless lines and good fluid (ATE Superblue.....Castrol....).
Mattj
Old Dec 3, 2002 | 07:05 PM
Willard's Avatar
which ones do u guys suggest? (so like 70%street 30%track)...
The DS2500's and P+'s are both very nice for street and light track use.
ATE super blue is cheap and works quite well.
Not unless you have a leak from your stock units.
Old Dec 3, 2002 | 09:33 PM
io_burn's Avatar
New User
Default Re: time to change brake pads, which one should i get? (Willard)
The Axiis pads... they're $92.25 for a front set. Do you need to buy two front sets (one for each wheel) or does a front set include 4 pads?
Old Dec 3, 2002 | 09:43 PM
Dave-ROR's Avatar
Default Re: time to change brake pads, which one should i get? (io_burn)
front set of pads includes 4 pads
Old Dec 4, 2002 | 03:18 AM
RedR's Avatar
Default Re: time to change brake pads, which one should i get? (Dave-ROR)
is this kit good ?
http://www.fastbrakes.com/pages/kits/integracivic11.htm
Old Dec 4, 2002 | 03:48 AM
DutchITR1689's Avatar
Ferodo DS2500 is my advice...
Old Dec 4, 2002 | 06:35 AM
natedoggs2k's Avatar
You can't go wrong with Hawk or EBC Green stuff!
Old Dec 4, 2002 | 07:02 AM
nsxtcjr's Avatar
New User
Andie Lin (this is how he spells it) used to work for Carbotech before he started his own company, Cobalt Friction. He resells other manufacturers' brake products and is also having some of his own made up. No, we don't work for him - we just all wish we did.
He:
- is extremely knowledgeable about all brake products, including those he sells as well as other, and is happy to share this knowledge. That's why, even though a lot of people here are giving you good advice, you're better off talking with Andie. You can discuss your needs and he'll tell you what's best for you.
- is selling some products that are better than anyone else's. For example... You asked about brake fluid. He sells a fluid that has higher boiling points (that means it's better) than either ATE Super Blue or Motul RBF 600, the two most-frequently-recommended high performance brake fluids, and at a reasonable price too.
- sells products at great prices.
- is providing sponsorship money to the ITR Expo 3.
- is donating a portion of sales to ITRCA members to ITR Expo 3 in addition to his sponsorship money.
- is (in case it's not apparent from all of this) a really nice guy, too.
Does this make him a brake god? You betcha.
[Modified by censored, 10:05 AM 12/4/2002]
Ms.JDMdb8
Jul 8, 2005 03:53 PM
Draggin99Si
Jan 21, 2003 09:58 PM
TRE_
12
Aug 11, 2002 09:53 AM
citanest
18
Jul 6, 2001 01:41 PM
