would fidanza flywheel fit with any other clutches?
Old Dec 3, 2002 | 04:31 PM
meltSolid's Avatar
Default would fidanza flywheel fit with any other clutches?
let say if i get the fidanza flywheel, would this fit with CM clutches or Exedy clutches?
Or has to be CM clutches with CM flywheel, and Exedy with exedy?
thanx
Old Dec 3, 2002 | 04:52 PM
Smitdog's Avatar
Default Re: would fidanza flywheel fit with any other clutches? (meltSolid)
U get a clutch for the correct car and a flywheel for the correct car, name brand almost never matters if it will work or fit. You will be fine.
Old Dec 3, 2002 | 05:12 PM
Dropspeed's Avatar
FYI Fidanza makes the clutchmasters flywheel, Same thing.
Old Dec 3, 2002 | 05:14 PM
ZygSpeed's Avatar
Default Re: would fidanza flywheel fit with any other clutches? (Dropspeed)
Doesn't Clutchmasters also sell a Chro-Mo/Steel flywheel?
meltSolid's Avatar
Default Re: would fidanza flywheel fit with any other clutches? (Smitdog)
thanx alot.
so doesn't matter if i get different brand for flywheel and clutches right.
another thing, do u know how long would those 3 puck clutches last?
in terms of KM or miles? (let say exedy metallic race clutch)
Old Dec 3, 2002 | 11:33 PM
vteg's Avatar
New User
thanx alot.
Correct. I don't know about pucks. I am scared of them. Try to get a lightweight flywheel with a replaceable face plate though. I think the pucks may chew it up.
1Bluegsr
Nov 25, 2011 05:05 PM
immalooser
Oct 18, 2005 08:08 PM
b16a27
Nov 5, 2004 04:43 PM
Rocks
Aug 23, 2004 12:27 PM
electrosi
Jan 31, 2003 02:27 PM
