Brembo vs Mugen?
I was curious to see if any one has had experience with ether system.
I was looking for Brembo Gold's but I could not find a place to buy them, I did though find the Grand Turismo System for $2395.
Gran Turismo Brake Systems
The next performance level, Gran Turismo, is comprised of both 1 or 2-piece vented rotors that are 12 to 14 inch cross-drilled and/or slotted. In the 2-piece system, billet aluminum hats are application specific and have been individually machined to engineering specifications. The marriage of these pieces create a "floating disc" which reduces heat related stress and improves brake performance and pedal feel. The Gran Turismo system may be available with your choice of black, red or silver calipers
Can anyone give me some good information on the comparison of these two systems?
I know that the Mugen is 2 piston and the Brembo GT's are 4.
Mugen is just S2k calipers. Both are mucho buckaroos for braking that could probably be had by doing the NSX calipers and Legend GS rotors with good pads. Just trying to save you some money.
What I want to know is if there is a significant difference between the two systems And if any knows where I can get Brembo Golds and for what price.
I think that I have a friend with the Brembo big brake kit that is looking to sell it considering he no longer owns a Type-R...requires 17's, but some 16's will fit.
have you looked at stoptechs kits?
i have heard very good things about those
remember that 90% of the time, if you have track pads and sticky track tires with stock brakes, it will most likely out perform daily driven pads with sticky street tires
i vote for light weight wheels, kumho v700 or yoko A032R 15" light wheels with cobalt gt-r spec compounds.
but, if you have lightweight wheels, great pads, sticky *** tires, and 13" rotors with 4 piston calipers. that will of course kick some ***
iggy, list what your goals you have, and what you are unhappy about the itr brake setup!
The reason I don't want a Stoptech kit like the one that Yoshi is using is because it would require 17 inch rims, I don't want to go over 16.
There is nothing wrong with, or nothing I dislike about the Stock set up. What I am trying to do is plann out my mods so that I have a well balanced reliable car. I would like to use Mugen but I don't want to go with the wrong choice with brakes because they could potentially save my life.
My next mod is a Mugen S1 seat and harness. Then I want to do some instructional track driving. But for the long run, Brakes would be next, and with that I would then upgrade rims and tires. My last mod would concern suspention, because the stock system has a lot of potential and when upgrade that I am spending big bucks.
I think I saw one (or two) of those brembo "gold" kits at Inline-Pro a week or two ago.
Very nice 13" (the Brembo kits), but I decided to go with some Smurf calipers under the stock wheels.
why not get a set of Spoon calipers with the fluid and upgraded pads?
Question:
What is wrong with your stock brakes?
:ducks and runs:
Question:
:ducks and runs:
:ducks and runs:
A good set of pads and some good fluid should be fine, but some want to change it...I know that I was looking at it...still haven't found a way to justify it yet.
Austin
Austin
Austin
I don't want the spoon calipers because they come with just the calipers, these that i have described are systems. They include pads, rotors, lines and calipers. I would prefer not to mix and match parts, with a system I have a balanced system because the parts were made to work together. The benifit though of the Spoons is they can use stock size pads.
Other more complete kits require the use of two piece rotors, dog bone extensions for the calipers, different brake pads, and various other non OE things. Most of thse parts were not designed specificaly for the R and have simply been pulled from a bin of parts. This is not necisarily a bad thing but does sort of go against your argument against the Spoon calipers.
Buying replacement parts for these complete kits will be pricy and less streight foward. With the spoon calipers you can walk into you local dealership and buy replacement rotors and pads. Something you'll be doing alot of if you track your car.
Just something to think about...
There is nothing un-balanced about the Spoon calipers. They were designed specificaly around the TypeR and it's otherwise stock equipment (rotors, MC, wheels, brake pads, etc). If anything they are the most "balanced" option out there.
[Modified by IGGY, 11:36 AM 12/3/2002]
Since you aren't road racing in a competitive form, keep the stock brakes and get some pads, fluids and lines. It is only around 300 bux and it will be an improvement over stock and wont bump you up classes at autox and wont make you add weight to your car if you ever do road race competitively.
You obviously dont have the disposable income to spend 2k on a braking "system" and if you aren't doing any real racing, big brake kits are just bling.
Just do whatever u want man..
like reading your post pisses me off..
when other people recommand u "What about stoptech?" ==== I dont like stoptech cuz. blah blah blah... and "what about spoon calipers"==== i dont like spoon calipers cuz it only comes with caliper..
spoon is made to work with stock rotor, that's why it comes with caliper ONLY..
looks like you are not "track" experienced and i dont know what other "PERFECT" parts you use for your mod but i just dont give a ****.
"i dont wanna put cheap parts on my car.. yeah.. sure.. but what other mod u have?"
"i want relieable car" for example. getting a legen rotor + nsx caliper wont make your car UNrelieable or missbalanced at all.
do what the fugg ever u wanna do man.. damn.. wasted my fugging 5 mins
[Modified by itr1244, 8:08 PM 12/3/2002]
Have you done any track driving yet? I wouldnt mess with it until your skills are more so then the cars.
Even the itr seat is fine if you use your seatbelt correctly.
upgraded pads+dot4 fluid+taking the slack out of the seatbelt+hpde= "stock" fun
Austin
post whoring to showoff the new avatar
shi - who
s his stoptech, but knows it's not for everyone
