Why my cat rattles... or... How to save half a pound :P
Old Dec 2, 2002 | 06:57 PM
AssPenny's Avatar
Default Why my cat rattles... or... How to save half a pound :P
Today on the way to work it sounded like my exhaust pipe was draging on the ground. So I jack up the car when I get home from work and I find this
1 weld in the corner left so I pull out a screw driver and a bfh and pop off the top shield
Sounds better now, but there is still a rattle, whether it is in the cat or header or what not, its not bad and I can cover it up with the radio
Rotated my tires while I was at it too... AC jack roxors
Old Dec 2, 2002 | 07:04 PM
Mugen Mike's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (AssPenny)
Just go back to open header, then you won't hear any rattles
MugenMike, who also had to rotate tires (and should take out a little camber )
sackdz's Avatar
That jack is the ish though, thanks for letting me borrow it
Old Dec 2, 2002 | 07:05 PM
disordeR's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (MugenMike)
nice camber wear!
Old Dec 2, 2002 | 07:06 PM
B2FiNiTY's Avatar
I want that jack!
Old Dec 2, 2002 | 07:11 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Why my cat rattles... or... How to save half a pound :P (B2FiNiTY)
I want that jack!
Ill take the calipers too!
Old Dec 2, 2002 | 07:13 PM
AssPenny's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (sackdz)
Hell yeah it is... best part is the bottom is a solid plate about 1/4 of an inch from the ground. That way when you us it in the grass (ie Camp We-Todd) it does not sink in the ground
[Modified by AssPenny, 11:13 PM 12/2/2002]
Old Dec 2, 2002 | 08:03 PM
Splat's Avatar
Collector-o-Guns and Drinker
What? No open header?
Old Dec 2, 2002 | 08:08 PM
Willard's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (Splat)
LMAO!
1234567890
Old Dec 2, 2002 | 08:11 PM
Buckshot's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (Willard)
how much is that jack?
XR4racer's Avatar
must not have been an SMSP cat.
Old Dec 2, 2002 | 08:22 PM
sackdz's Avatar
1234567890
Old Dec 2, 2002 | 08:23 PM
AssPenny's Avatar
Sorry, its a little loud driving to work, and as much as I try to convince myself... chicks DON'T dig it
It was from a group buy on here a while ago... I think it was like 180 shipped or something like that, then 10 bux more for that ghey rubber bad that does not fit and collects dust on the bottom of my tool chest
It was a carsound from some where, not sure, but I know it was not SMSP. I already had the cat on the car when I saw how he added more welds (my dad has a spot welder, would have been cake), but I was too damn lazzy to take it off (that top b-pipe bolt is a pita).
Oh well, I'm sure more things will evently fall off too Damn ware items
Craig - Who needs to do a 30k mile toon up soon
[Modified by AssPenny, 12:24 AM 12/3/2002]
Old Dec 2, 2002 | 09:23 PM
jdmspoonitr's Avatar
Sorry for the OT, but what tools are you guys using to hit that third top bolt? Without removing the b-pipe and cat, I really don't see a way to get it perfectly tight with the little space given. I ended up using a ratchet and a hinged extension so that it could get to that bolt, but it was still a bitch because I could barely turn the damn thing a couple millimeters at a time. thanks for the info
Old Dec 2, 2002 | 10:19 PM
Calavera's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (jdmspoonitr)
you have very flexible fingers.
[Modified by Calavera, 11:20 PM 12/2/2002]
Old Dec 3, 2002 | 04:27 AM
Ricky Rojales's Avatar
Negative camber 0wnz
Old Dec 3, 2002 | 04:41 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Why my cat rattles... or... How to save half a pound :P (P)
Hahaha wh0a! camber.
Old Dec 3, 2002 | 07:10 AM
Hooch'n's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (integra707)
...looks like the hatchcrap!
Old Dec 3, 2002 | 07:31 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Why my cat rattles... or... How to save half a pound :P (Hooch at 8400-RPM)
That ain't no RRRR, that's a mazda!!
Old Dec 3, 2002 | 10:52 AM
Big Phat R's Avatar
I bet you your interior is going to be a lot warmer in the future without the heatshield on that cat. Careful that you don't melt anything or set the ground on fire when you park your car in longer grass (i.e. WeTodd picnic style)
Old Dec 3, 2002 | 11:01 AM
ILLTEGRA
Guest
Posts: n/a
Default Re: Why my cat rattles... or... How to save half a pound :P (Big Phat R)
i had the same problem with my heat sheild, started rattling like crazy.
so i took it off. now my car is so quite and i had no problem so far.
i live in canada and its more cold here so i think that helps my car from heating up.
when i drive my car in the winter, it sort of feels like i have a Aem intake..
Old Dec 3, 2002 | 11:09 AM
dimsum's Avatar
That looks just like what my Random Technology catalytic converter looked like a few years ago. I just had a shop weld the heat shield back on. I figure it was there for a purpose, so might as well keep it on there.
If you still have some rattles, it might be coming from some loose chunks of honeycomb bouncing around inside your cat. Remove the cat and dump all that garbage out before it gets lodged in your piping somewhere and blocks up your exhaust. Once that happens, you won't have any power past 4000 rpms.
Old Dec 3, 2002 | 11:32 AM
SloEG's Avatar
Are you planning to sell that cat heatshield?
Old Dec 3, 2002 | 01:37 PM
AssPenny's Avatar
Default Re: Why my cat rattles... or... How to save half a pound :P (SloEG)
ummm no, i plan on welding it back on if i ever get off my lazy *** and take the cat off
Old Dec 3, 2002 | 04:56 PM
SloEG's Avatar
Damn
