help with brakes please
Old Dec 2, 2002 | 12:58 PM
deviant1's Avatar
Default help with brakes please
Whenever i brake at lower speeds to a complete stop (about 40 to 0) the car feels like its stuttering or shuddering. its hard to explain. its not like the engine is dying but its whenever i brake. kinda feels like something is warped. maybe my rotors? please help. TIA
Old Dec 2, 2002 | 12:59 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: help with brakes please (deviant1)
rotors are warped.
Old Dec 2, 2002 | 01:01 PM
mantic6t9's Avatar
Default Re: help with brakes please (vtecvoodoo)
rotors are warped.
Yep.............
Old Dec 2, 2002 | 01:11 PM
deviant1's Avatar
Default Re: help with brakes please (mantic6t9)
it would have nothing to do with bleeding the brakes or my pads? i suppose you cant resurface the rotors, huh? time for new ones i guess. any recommendations? also, you dont need to bleed the brakes if you are just replacing rotors, right? TIA
Old Dec 2, 2002 | 01:28 PM
mantic6t9's Avatar
I don't think it has anything to do with your pad or braking system. Yes you can resurface them but rotors are cheap so why not get new ones. Go to AutoZone and pick up a set they are aroung $25 each.
Old Dec 2, 2002 | 09:44 PM
euclid's Avatar
its all about the autozone rotors. waranty, plus no shipping charges.
Old Dec 2, 2002 | 10:09 PM
BlackDeuceCoupe's Avatar
HT White Ops
rotors are warped.
More likely cracked rotors and/or pad material build-up. Resurfacing won't do ****...
SOURCE: http://www.stoptech.com/whitepapers/...otors_myth.htm
<FONT COLOR="blue"> Myth # 1 - brake judder and vibration is caused by discs that have been warped from excessive heat. </FONT>
The term "warped brake disc" has been in common use in motor racing for decades. When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
When disc brakes for high performance cars arrived on the scene we began to hear of "warped brake discs" on road going cars, with the same analyses and diagnoses. Typically, the discs are resurfaced to cure the problem and, equally typically, after a relatively short time the roughness or vibration comes back. Brake roughness has caused a significant number of cars to be bought back by their manufacturers under the "lemon laws". This has been going on for decades now - and, like most things that we have cast in stone, the diagnoses are wrong.
In more than 40 years of professional racing, including the Shelby/Ford GT 40s - the most intense brake development program in history - I have never seen a warped brake disc.... I have seen lots of cracked discs, discs that had turned into shallow cones at operating temperature because they were mounted rigidly to their attachment bells or top hats, a few where the friction surface had collapsed in the area between straight radial interior vanes, and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not.
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. In order to understand what is happening here, we will briefly investigate the nature of the stopping power of the disc brake system...
(Go to the link above for the rest of the story - too long for this thread - BDC)
Old Dec 2, 2002 | 10:13 PM
JDMvtecDRAGSTA's Avatar
Default Re: help with brakes please (BlackDeuceCoupe)
man everytime i read a post by BDC its so long and very informative.
Old Dec 2, 2002 | 11:40 PM
chillly's Avatar
That is a great link
Old Dec 2, 2002 | 11:56 PM
hanson said's Avatar
Default Re: help with brakes please (uncivilCivicinprogress)
it's good to know "the real problem" as well as the proper solution.
thanks.
Old Dec 3, 2002 | 03:37 AM
shawnhayes's Avatar
Bullshit junior. You didn't read the whole article.
From your link:
"The only fix for extensive uneven deposits involves dismounting the discs and having them blanchard ground - not expensive, but inconvenient at best."
So, unless it's cracked, according to your posted article, resurfacing WILL fix the problem and a proper break in procedure will prevent it from returning. You might wanna read what you post before you fly off the handle full of ****.
Shawn
[Modified by shawnhayes, 7:54 AM 12/3/2002]
Old Dec 3, 2002 | 02:29 PM
Default Re: help with brakes please (shawnhayes)
i was thinking the same, but if you get the rotors resurfaced, then there really wouldn't be any of the coating left to break in. am i right in my way of thinking here?
Old Dec 3, 2002 | 03:41 PM
shawnhayes's Avatar
Default Re: help with brakes please (hanson said)
According to the article as posted, yes.
When people resurface, and the problem goes away briefly, this uneven transfer is probably to blame. "warped" or out of true discs do occur, but they are rarer than most people think.
Resurfacing and rebedding the pads properly may clear up the problem.
Shawn
Old Dec 3, 2002 | 03:48 PM
cool. so the break in procedure would soley be for the pads in a resurfaced-rotor condition?
Old Dec 3, 2002 | 03:58 PM
shawnhayes's Avatar
It's best to rebed ANY new pad and ANY new rotor. Some companies suggest new rotors with old pads for some time, and new pads with old rotors. If the new pad or new rotor are similar compounds to the old, theoretically the bedding procedure should be a little less restrictive under these conditions. I'm not sure how correct this theory is, however.
Shawn
Old Dec 3, 2002 | 04:17 PM
ahh, ok. i think i follow. i love honda-tech. information exchange at it's finest.
Old Dec 3, 2002 | 10:50 PM
DMF's Avatar
DMF
warped rotor...have them machined....
Old Dec 12, 2002 | 11:03 PM
deviant1's Avatar
Default Re: help with brakes please (DMF)
so i revisited this post because i was about to buy $17 brembo blanks from nopi.com and i read it all again. now my question is, 1)do i need to buy new brake pads as well as new rotors (pad material build up)? and 2)should i just get the rotors i have now resurfaced? which will fix the problem?
[Modified by deviant1, 12:06 AM 12/13/2002]
Old Dec 13, 2002 | 06:54 PM
shawnhayes's Avatar
No, you shouldn't need new brake pads unless the ones you have are crap. (remember, they could possibly be causing uneven transfer because of poor quality).
Machining the current rotors may fix the problem, but if you are abusing the brakes or not bedding the pad in properly, the problem will come right back.
Shawn
Old Dec 14, 2002 | 01:23 PM
i'm just kinda thinkin out loud here, but could not bleeding the brakes lead to uneven pad contact and lead to the build up we all want to avoid? just trying to explore some of the reasons pad build up occurs so it won't be an issue.
sin2o3
Sep 5, 2007 12:20 PM
skimeast1982
Oct 18, 2006 04:31 AM
Vt3c_eg
10
Feb 16, 2006 08:59 PM
1hotintegra
Aug 7, 2002 06:52 AM
TsunamiZC
Jul 23, 2002 11:51 AM
