Picture request: Fuel Filter and lines running to and from
Old Dec 2, 2002 | 10:33 AM
RTW DC2R's Avatar
Default Picture request: Fuel Filter and lines running to and from
I need to order a new line that runs from the top of the fuel filter, but I cant figure out what piece it is on the Acura Automotive Parts diagram. Im guessing most Honda setups are the same or very similar looking. can someone post a pic??
Old Dec 2, 2002 | 10:52 AM
sackdz's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (RTW DC2)
#4..... $58
[Modified by sackdz, 2:52 PM 12/2/2002]
Old Dec 2, 2002 | 11:03 AM
Mase's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (sackdz)
yep those banjo fittings are expensive.....id check the junk yard for a wrecked integra...
Old Dec 2, 2002 | 11:17 AM
Philly_NBP_R's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (Mase)
on the subject of fuel filters... any suggestions on where to order a replacement? are the K&N ones worth the extra $$ ?
thanks
Old Dec 2, 2002 | 11:21 AM
ITR21's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (Philly_NBP_R)
how often are you guys changing your fuel filters?
Old Dec 2, 2002 | 11:25 AM
B16CRX's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (ITR21)
I usually do fuel filter every 15K.
Old Dec 2, 2002 | 11:29 AM
uNF$@#!'s Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (B16CRX)
same, but i occaisionally put molasses in my fuel tank for fun
Old Dec 2, 2002 | 11:43 AM
RTW DC2R's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (Soup ****)
thanks sack...thats the diagram i was lookin at but wasnt sure if that was the fuel filter or not now, I still have the top portion of that line on my filter, but the thieves cut the line about halfway down. you think its possible to just clamp another line to that or should i just get an entire new line??
Old Dec 2, 2002 | 11:52 AM
nortrop's Avatar
I would get a new line as it carries fuel at a high pressure. The last thing you want is to have fuel spraying onto the back of you r exhaust manifold.
Old Dec 2, 2002 | 12:20 PM
Rob Dizzle's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (nortrop)
The 2000 SI fuel feed line is only 25 dollars from the honda dealer
pretty much same length.
I have a gsr with skunk2 intake manifold, i had to find a longer line to work with my intake
the si has plenty of slack. it is the same or just a lil longer than the itr
edit: also remember to buy new washers from the dealer, you need to normal washers that attach to the top and bottom of the banjo fittings at the fuel filter end, then you need a weird shaped washer at the end of the fuel rail
[Modified by Bob-DC2, 1:21 PM 12/2/2002]
Old Dec 2, 2002 | 01:34 PM
Tweakmeister's Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (Bob-DC2)
btw
the fuel filter is just another paper filter.
yes, I sawed mine in half, and yes, I have pictures
Old Dec 2, 2002 | 01:45 PM
uNF$@#!'s Avatar
Default Re: Picture request: Fuel Filter and lines running to and from (Tweakmeister)
post! post! I didnt take a hacksaw to mine yet
Old Dec 2, 2002 | 01:59 PM
Mase's Avatar
Here are the pics of a fuel filter off my buddy's civic. It took me forever to get that stupid thing apart.
P.S. dont you love my dirty fingernails?
[Modified by Mase, 3:00 PM 12/2/2002]
Old Dec 2, 2002 | 02:09 PM
TRuST's Avatar
Wow, you do that to. I put soap in mine so that I have cleaners fuels and a cleaner burn in the combustion chamber.
Serious note.
I would go to the junk yard and find the banjo bolt.
B18IntegraLS
Apr 2, 2010 07:43 AM
eg:R
Mar 31, 2010 05:37 PM
I B BANGGIN
Jan 14, 2007 06:57 PM
CPR
Sep 27, 2004 07:10 AM
Muckman
Dec 9, 2002 01:09 PM
