check engine codes...
i have a d16z6 with p28 ecu in my rex. i am getting code #1 and #7? i think the #1 is 02 sensor, not sure what the 7 is? please let me know. thanks
#1 is Oxygen Sensor "A" (Primary)
#7TDC Sensor (Top Dead Center)
correct me if im wrong pretty sure tho
check if they r unplugged first if not either defective circut or sensor
ok well, i am so amazed i haven't blown my ish up yet. after 6 long COLD days of fighting tring to put this turbo kit on my crx, everything that could go wrong or be in the way happened. last night as it got dark, i got in a hurry tring to hook the cheap temporary black box up (old greddy kit). well... code 7 is tps. yea, i seen the black/white wire and thought i had the right sensor to tap into.(it was supposed to splice into the IAT (intake air temp) sensor. that is why i have code 7. i need to fix that tomorrow. then that same green wire on the black box is supposed to tap into the ECT (engine coolant temp) sensor. there are two sensors right by the upper radiator hose. next to that hose, and kind of under the dizzy. what are those called. i think that is where the coolant temp sensor is. and does it have two wires or one? yes peeps i know. i am going to get the missing link and ditch the box, but for now i need to fix the mess i made by rushing.
i know i am a dip-****, so please keep coments out, just help me find the right damn sensor to tap this green wire into. thanks
DisplacedMic
Jul 27, 2016 12:33 PM
