Anyone here using the NUFORMZ Honda drag rear suspension kit ?
Old Dec 2, 2002 | 06:42 AM
CHEETAH's Avatar
Default Anyone here using the NUFORMZ Honda drag rear suspension kit ?
Its int he latest turbo mag, comes with Weld aluminum rear skinnies.
My question is the article says weight savings for 70-90 lbs including wheels, now is this measured from stock wheels to the racing alumnumi skinnies ? that alone is about 60 lbs weight savings so does the rear suspension really save that much weight ? I really want to get this setup for my CHEETAH but not if its gonna cost a bundle with very minimal weight savings (compared to lets say the MMR/MB kit).
Greg
Old Dec 2, 2002 | 07:33 AM
earl's Avatar
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (CHEETAH)
Good question. I've always wondered about that claim also. Pulling the wheels out of the equation, I can't see that much of a savings. Also, once you set it on the wheelie bar, does it really matter what shock is on the car? The brake system is nice but that is just used for staging and not stopping.
IMALLSLO's Avatar
I have it but havent used it on the track yet(testing and tuning by Feb.) . My kit was one of the first protypes from 3 years ago. The kit itself is quite pricey but the weight savings are huge from a factory suspension/trailing arm setup.
There are a couple of other quick class racers that have this setup already and have nothin but good results.
[Modified by proclassracer, 8:37 AM 12/2/2002]
[Modified by proclassracer, 8:46 AM 12/2/2002]
Old Dec 2, 2002 | 08:28 AM
CHEETAH's Avatar
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (proclassracer)
Earl, I think the article said Jotech uses it maybe Tony can shed some light on this ...
proclassracer, so the weight savings on your prototype WITHOUT wheels is significant like how much ? 50 -80 lbs ? any idea ? also, how is the wheel offset relative to the rear 1/4 fender when the rear is dramatically lowered ? have you tried it yet ?
most of all, what kind of pricing you remember ?
thanks,
Greg
Old Dec 2, 2002 | 08:42 AM
tony1's Avatar
We run it on our car. We used to run the RPM rear suspension setup. It was a little lighter than stock but not much. When i installed the nuformz I weighed it all. The whole kit, still in the box it came in, weighed 45lbs. This is without the wheels. When i took off the rpm stuff I weighed one whole side (w/o wheels) and it was 40lbs. Keep in mind the nuformz came with a staging brake and lines too. All in all, the kit is 35lbs. lighter than the rpm. Another thing is the brakes. The rotors that come with the nuformz kit are so light its ridiculous. It's like picking up a piece of cardboard or something. This is especially good since this is rotating weight. I don't think the wheels are really much lighter than the bogarts so I wouldn't really consider that a factor. Other than that, they just look cool!
Old Dec 2, 2002 | 12:17 PM
IMALLSLO's Avatar
It may be a little hard to see but here when lowered on the ground it is tucking quite nice with no cutting
I dont remember how much weight was saved but I remember somewhere over 50 -60 lbs without wheeels. The list price on this kit was around 4500 without wheels.
Old Dec 2, 2002 | 12:23 PM
CHEETAH's Avatar
thanks tony ...
proclassracer, nice race car, I hope you're not all motor but looks liek you are with that scoop ?
thanks for the info, weight and braking setup is top notch, but LOL $4500 jesus mother ... its well worth it but damn.
I wonder if I really need those shocks with wheelie bars for an all motor car ?
Greg
Old Dec 2, 2002 | 12:55 PM
CheezeFrog's Avatar
How streetable is that setup?
Old Dec 2, 2002 | 12:57 PM
bambooluv's Avatar
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (CheezeFrog)
its not streetable at all spindle mounted rims be hard to change if you got a flat
and the the size tire you could fit on it would put you in harmes way trying to make a harshturn. my 2 pennies-pdang
Old Dec 2, 2002 | 01:46 PM
kentucky accord's Avatar
before you go and spend 4500 bucks on a rear suspension, try giving Nate Romero of Race101.com an e-mail. he makes custom rear ends for vw's and hondas both of which help them cut 1.5-1.6 60fts all day long.
give him all the details of what you want and/or need and he will help any way he can im sure. he has been a pro-racer for quite some time and hell, you may even know him.
he owns the fastest fwd all motor VW in the country.
http://www.race101.com contact info is on the page.
[Modified by kentucky accord, 7:47 PM 12/2/2002]
Old Dec 2, 2002 | 03:12 PM
Suprdave's Avatar
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (kentucky accord)
I saw the Civic Rear suspension on the Black Civic...I did not like the workmanship at all from what I saw.
The quality isn't even close to the Nuformz Kit...It was a Solid Rear Suspension...noone run's that really...Can't fight Physics...gotta work with it.
Suprdave
Old Dec 2, 2002 | 03:22 PM
MackSpeed-616's Avatar
ahhh the PROfessor
Old Dec 2, 2002 | 04:31 PM
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (Suprdave)
i have always been a strong believer of function over fashion. i know one thing, his rear end on his race corrado only weighs 14lbs. besides, they must be doing something right, 1.5-1.6 60's aint too shabby.
im not saying its for everyone and im not trying to make a sale for nate either, i was just trying to shed some light on other areas.
take care.
Old Dec 2, 2002 | 06:16 PM
earl's Avatar
Remember with the suspension, you got to stop them properly also.
Old Dec 2, 2002 | 06:51 PM
TEAMGENDAI's Avatar
Damn chris the car looks almost sexy as you!!!!
j/p
Old Dec 3, 2002 | 12:05 AM
Suprdave's Avatar
Actually, ina Gutted Racecar...with custom, solid rear end...I wouldn't consider a 1.5-1.6 good at all. Now if your knocking on 1.4s with that setup...I would pay homage.
Charlie (From B20vtec.com) on this Board, went 1.55 60-ft with Apex N1 Suspension, stock. Food for Thought...
Suprdave
Old Dec 3, 2002 | 12:23 AM
simple4012's Avatar
New User
yea we were able to pull good 60's with our setup last season...we got better and better as the season progressed. Hopefully we will continue the trend next season. We have a few new tricks up our sleeves coming, Solid rear axle....doors (finally) and a totally new engine setup....and yes we are getting rid of that silly old stock ecu and vafc. Crossing our fingers for high 1.4's next season consistently. Maybe if we ever got that thing on a dyno it would have helped lol....
Old Dec 3, 2002 | 08:29 AM
Suprdave's Avatar
Default Re: Anyone here using the NUFORMZ Honda drag rear suspension kit ? (simple4012)
Locked Rear Suspension isn't the answer to good 60ft's.
A Fast-Rebounding Shock paired with a Semi-Heavy Spring is, IMHO.
Either that, or a Fast Rebounding shock, light spring, and Wheelie Bars...
Even with the Linked-Rear Suspension...yu need 'Something' that gives alittle.
Suprdave
Old Dec 3, 2002 | 12:00 PM
you must not have looked very close to the rear end setup on the civic, its not locked.
as i said before i was just trying to shed light on other options.
personally, spending very little $$ on materials and doing it myself is worth the .05 on the 60ft, compared to spending $4500 bucks for a ready made unit and be lighter at the same time.
edit: this doesnt give a very good shot of the rear end but its the best one i could scrounge up.......
http://www.race101.com/images/ovis_6...s/DSC01464.jpg
[Modified by kentucky accord, 6:05 PM 12/3/2002]
Old Dec 3, 2002 | 01:00 PM
IMALLSLO's Avatar
Actually turbo methanol, and the scoop was a last minute blunder. It going to be changed before testing. Thanks. [b] WHAT UP BUBBAAAAAAA!
Old Dec 4, 2002 | 06:41 AM
CHEETAH's Avatar
lol, thats not funny but it kind of is ... my autobody sponsor put a chevy S10 blazer scoop on my front end, and man it looks like it belongs there, now if I had seen your scoop I would have hopped on that.
BTW, your car looks mean as hell, also heard that from a pro racer with a mid 9 sec Honda who gave your car props, jsut an FYI you're doing a cool job with your car.
Greg
Dark_Teg
Sep 3, 2009 06:09 PM
danimaltron
Honda Civic (2006 - 2015)
Jun 13, 2007 11:14 PM
.dave
Jun 21, 2006 06:52 AM
xci_ed6
Welding / Fabrication
Feb 10, 2006 07:24 AM
Mr.E.G.
Dec 6, 2005 04:30 AM
