Question about No. One Cylinder
Old Dec 1, 2002 | 09:13 PM
jdmsol's Avatar
Default Question about No. One Cylinder
I've got a CEL code number 9 and I was wondering if this could be a result of bad spark plug wires. I replaced the CYP sensor a year ago come January. Thanks in advance.
Old Dec 1, 2002 | 09:25 PM
b19coupe's Avatar
Default Re: Question about No. One Cylinder (jdmsol)
No. If you are OBDII, you will get a misfire code with really bad spark plug wires. Code 9 indicates a problem in the distributor or wiring.
Old Dec 1, 2002 | 09:26 PM
jdmsol's Avatar
Default Re: Question about No. One Cylinder (b19coupe)
OBDI...D16Z6
Old Dec 2, 2002 | 05:23 AM
jdmsol's Avatar
Anyone?
Old Dec 2, 2002 | 05:57 AM
b19coupe's Avatar
Code #9, as you know, is the CYP sensor. It is in the distributor on the D16. The problem is either the sensor itself, which requires distributor replacement, or in the wiring between the ECU and the distributor.
[Modified by b19coupe, 2:57 PM 12/2/2002]
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
Nathan_volcom
Oct 21, 2011 05:49 AM
93redDA
Sep 5, 2010 02:31 PM
jedb18
May 31, 2008 12:32 PM
turbob18si
Dec 3, 2006 04:02 PM
