How to install front and rear speakers on 4th gen accord?
Can somebody tell me how to install speakers for my 4th gen accord....This is my first time installing speakers....so I have no clue where to start...Also I bought 2 6"x9" dual cone speakers and two 6" speakers....which one goes to the front and which one goes to the back....??? Thanks for all your help....
can you be more specific about the front ones cuz I want to know if I have to take out the door panel to install the front speakers....
You probably only have to unscrew or pop off the grill cover. If you see screws then unscrew it, if not find a spot and give it a tug, most Honda interior crap is held on with clicks, pull hard enough and it should come off.
first off, take off the black triangle piece opposite the side view mirror, then theres a screw behind your door handle lever, some near the handle in the door near your window controls, if you dont have power windows you gotta get the roller thing off for the window. i think the trim around the handle comes off..... but you gotta slide it forward. make sure and get all the screws b4 you pop the door off ... when you do get all the screws it should pop off, be carefull of door light plugs and window plugs(if you have them)
