Safety Netrual switch?
Old Dec 1, 2002 | 04:39 PM
G-reX's Avatar
Default Safety Neutral switch?
The local track has stated that "Functional neutral safety switch are mandatory."
Now the question is how am I to go about doing this. My CRX doesn't come with one so what do I do. The track is going by the IHRA rules. So do all you guys have one.
[Modified by G-reX, 1:41 AM 12/2/2002]
Old Dec 1, 2002 | 04:42 PM
D-Man's Avatar
Default Re: Safety Neutral switch? (G-reX)
is your crx an automatic? you wont need one with a stick
Old Dec 1, 2002 | 05:34 PM
G-reX's Avatar
Default Re: Safety Neutral switch? (D-Man)
No its a stick. You don't need one? What about if your car will start in gear?
Old Dec 1, 2002 | 06:29 PM
D-Man's Avatar
Your CRX should have a clutch cut-off stock,you have to depress the clutch to start it but thats not a safety neutral switch,only autos have that.
Old Dec 2, 2002 | 02:59 PM
G-reX's Avatar
There is clutch cut off on mine or any of my friends CRX's.
Old Dec 2, 2002 | 10:09 PM
raene's Avatar
'88 CRXs did not come with them. I installed a cutoff switch in my CRX, in order to be legal.
sheeyit, now I wish I could find the instructions on how to do it... hang on... I drew it all up and mounted it with a custom bracket rather than install the entire pedal assembly.
OK, here it is: I used a C-shaped bracket, 1.8" on one end, 2.5" on the main section, and 1.25" on the final end. I cut holes in each end, 0.5" diameter on the bottom and 0.65" on the top in order to mount the switch and to bolt it to the pedal assembly. So it's like this:
.....\/ <-- hole here
...^ <-- hole here
Then you need to wire in the switch. You'll note that the plug that goes into the fusebox under the dash has a loop of wire in it, and that needs to be cut... here, I'll just scan in the 'diagram' I used and post it for ya . I hope this helps! Of course, you'll need to buy the switch from a wrecking yard and the wiring it's attached to. Don't forget to get the nut that holds it in place on the pedal assembly.
[Modified by raene, 11:10 PM 12/2/2002]
Old Dec 3, 2002 | 01:27 PM
G-reX's Avatar
Default Re: Safety Neutral switch? (raene)
Thanks dude I got it figured out now . Thanks.
viking-101
10
Feb 8, 2019 03:34 PM
ki11r0y1086
Jun 20, 2016 06:45 PM
crx2nr822
17
May 3, 2009 01:16 PM
mrchris1979
Apr 24, 2008 01:14 AM
Intocable
Mar 2, 2008 11:02 AM
