who makes Front LOWER bars?
Neuspeed makes a front lower tie bar ... but realize this ... if you have a dc sports header ... you will have to notch bar slightly so you dont rub a whole in one of your header's runners over time ...
also .. even more of a headache ... the 2 spots the bar mounts to is part of the subframe .. that the lower control arms bolts up to ... that spot .. has a nut ... welded on the INSIDE of the subframe piece ... and over time ... i guess my neuspeed bar worked over the welds of the nuts .. and broke them both loose ... and since there TOTALLY enclosed ... i had to take a grinder .. and gring 2 slits into the subframe piece to get a wrench on the back of these nuts ..
lots of hassle .... skip this lower tie bar mod .... just get some HUGE *** sway bars ... like Suspention Techniques .. and call it good
Spoon makes one, it's not bad but it tends to hang a little low and get hit or bent back by stuff. I still have my spoon tie bars on, and after my front got bent back I just left it like that and it seemd to be ok. But the Benen is nice too.
Cusco, a Japanese supsension tuner makes one for $86 http://www.optauto.com. Its blue, aluminum and easy to install. I had it but the Acura dealership bashed it on a center contact lift when my car needed a new control arm (lowered 2").
