wats the rev range on 94 jdm h22a
Old Nov 30, 2002 | 09:45 PM
Acclude's Avatar
Default wats the rev range on 94 jdm h22a
i did engine transplant in my 92 accord but my revs cuts out at 6500 rpm....how can i fix this prob.....is it a fuel cut or rev cut???? auto to manual conversion
Old Nov 30, 2002 | 09:49 PM
Mike95lude's Avatar
Default Re: wats the rev range on 94 jdm h22a (Acclude)
Sounds like your VTEC isn't working. I believe that is the fuel-cut for the low-cam.
Old Nov 30, 2002 | 09:57 PM
Acclude's Avatar
how do i fix it ??
Old Nov 30, 2002 | 10:09 PM
fastludeh22's Avatar
do you have any cel's? check your oil. if the oil pressure is too low vtec wont engage. the car also has to be warmed up for it to work. who did your swap? did you reverse the wire it says to? im not sure which 2 but it needs to be done in the accords...check out http://www.h22a.org
Old Nov 30, 2002 | 10:21 PM
drift's Avatar
New User
Default Re: wats the rev range on 94 jdm h22a (fastludeh22)
your car's wiring harness isnt VTEC compatible. did you wire up the new VTEC solenoid and are you using a compatible H22 ecu?
Old Nov 30, 2002 | 10:28 PM
Acclude's Avatar
Default Re: wats the rev range on 94 jdm h22a (drift)
im using h22a wiring loom and ecu all wiring a correct oil pressure is good..got a new vtec solonoid,oil pressure swicth,knock sensor, oil pressure sensor and o2 sensor compression is 195......don't know y rev cut so early...can it be that cat??
Old Nov 30, 2002 | 10:32 PM
satan_srv's Avatar
so do you have vtec or not?
Old Nov 30, 2002 | 10:37 PM
Acclude's Avatar
Default Re: wats the rev range on 94 jdm h22a (satan_srv)
yes i think i have ....my mechanic says i have
Old Nov 30, 2002 | 10:41 PM
rjr162's Avatar
you would know if you had it. it would switch over at about 5400, and you can tell the difference even by ear
Old Dec 2, 2002 | 12:59 AM
Acclude's Avatar
Default Re: wats the rev range on 94 jdm h22a (rjr162)
yea i hav vtec
Old Dec 2, 2002 | 12:14 PM
Honda Sport's Avatar
did you let the motor warm up before trying a WOT run? When the motor isn't warmed up to a certain temp., you're not able to take it pass 6500rpm.
Old Dec 2, 2002 | 12:29 PM
Finest's Avatar
Default Re: wats the rev range on 94 jdm h22a (Honda Sport)
Look on the ECU and tell us what numbers do you see.
Don't mistaken VTEC for the IAB's.
Old Dec 2, 2002 | 12:46 PM
Nick M's Avatar
Default Re: wats the rev range on 94 jdm h22a (Prelude_RCR)
6500 = safe or limp mode
What cel are you throwing?
LUDESWAP
May 2, 2011 09:45 PM
92cb7sk8er
Mar 29, 2011 05:43 PM
nelsond
Dec 4, 2006 12:22 PM
juicedprelude
Jul 10, 2003 02:42 PM
Acclude
Oct 4, 2002 01:10 AM
