my new brake setup
Old Nov 30, 2002 | 09:24 PM
spoon_ek9's Avatar
Default my new brake setup
i got my new rotors in my car. that is basically a 11/11.75" 4 piston brake kit from fastbrake. i got the 11" one. the 11" kit is using itr rotor redrill 4 X 100. the kit is not bad at all, however, the pad is not fully used. i contacted brian couple time and he wasn't able to find another rotor that could use up all the pad except the 11.75" 2 piece rotor(which will cost me 350). i almost got the 2 piece rotor at the time, but i tested fit my friend's 11.75" rotor from wilwood and the rotor will touch the caliper with the bracket that i have. i didnt get that from him because of that fitment issue(the inner pad also got an issue on the 11.75" rotor too). until now, i finally found something that works(all pad area is on the rotor) and much cheaper than the 2 piece rotor.
u can see the rotor is painted black on the hub and also the edge of the rotor.
this is the pad that used with the itr rotor. as u can see, there is 10% of the pad is not used(5mm over 45mm)
[Modified by spoon_ek9, 8:51 AM 12/1/2002]
[Modified by spoon_ek9, 10:00 PM 12/1/2002]
Old Nov 30, 2002 | 11:41 PM
ahcjar103's Avatar
Default Re: my new brake setup (spoon_ek9)
can't see the pics...
Old Dec 1, 2002 | 12:39 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: my new brake setup (ahcjar103)
Looks like the FastBrakes Red X kit.
Old Dec 1, 2002 | 06:28 AM
EleanoR's Avatar
Default Re: my new brake setup (SpoonSportsEH2)
Old Dec 1, 2002 | 06:50 AM
SlippylesKB's Avatar
Ah... It's so clear to me now
Old Dec 1, 2002 | 08:42 AM
EG6-SiR's Avatar
New User
Default Re: my new brake setup (SlippylesKB)
Old Dec 1, 2002 | 09:40 AM
TRE_'s Avatar
Default Re: my new brake setup (EG6-SiR)
LOL!!!!! HAHAHA!!! Thats fucked up but its still funny as ****!!
Old Dec 1, 2002 | 01:02 PM
spoon_ek9's Avatar
Default Re: my new brake setup (glowing_rotors)
thats funny to see others' response. is it really surprise that yahoo photo fail to load?
Old Dec 1, 2002 | 01:03 PM
STEALTHMODECOUPE's Avatar
i can see it..looks good bro
Old Dec 1, 2002 | 01:12 PM
nfiedler3's Avatar
Default Re: my new brake setup (STEALTHMODECOUPE)
nice anymore pics....
Old Dec 1, 2002 | 02:16 PM
owen_the_soyboy's Avatar
Default Re: my new brake setup (nfiedler3)
looks okay to me bro.
how do you like the Wilwood calipers? I gotta know!!!!!!!
I also have the ITR redrilled rotor setup but with ITR calipers now... and I am looking to a Wilwood setup... any chance you have a pic of the mounting bracket?
Old Dec 1, 2002 | 06:56 PM
spoon_ek9's Avatar
Default Re: my new brake setup (owen_the_soyboy)
i am using it with DS3000 now. very good stopping power. the pedal feeling is also very firm.
Old Dec 1, 2002 | 07:06 PM
Broken Gearbox's Avatar
looks good.
what kinda rims are those?
[Modified by dEF juNKie, 8:06 PM 12/1/2002]
Old Dec 1, 2002 | 08:04 PM
TurboIntegra's Avatar
Default Re: my new brake setup (dEF juNKie)
So which 11.75" rotor are you using? I wasnt clear on that part?
Old Dec 1, 2002 | 08:11 PM
Jonathan_ED3's Avatar
Default Re: my new brake setup (TurboIntegra)
I'm wondering too.
I have the 11" kit from Fastbrakes, and I don't like that some of my pad is not used..it's just annoying for some reason. lol.
Old Dec 1, 2002 | 08:30 PM
spoon_ek9's Avatar
Default Re: my new brake setup (hot_EG)
mine is 11.6" one piece rotor, i can get them, email me for more info.
Old Dec 1, 2002 | 09:55 PM
will it work with the regular 11" upgrade kit, or do you need the Wilwood upgrade for it?
I'm using the 11" upgrade with Integra calipers.
Old Dec 1, 2002 | 09:59 PM
ahcjar103's Avatar
nice setup. i have been considering it
Old Dec 2, 2002 | 04:35 AM
JDM_Sol's Avatar
nice set up....
Old Dec 2, 2002 | 06:33 AM
KStuned's Avatar
Default Re: my new brake setup (JDM_Sol)
did you bead blast your wilwood calipers? What up with them being so dull? Is that the old school wilwood caliper? I have wilwoods on my eg and the calipers look WAY different, and honestly if you can afford it, go with the 2 piece rotor. Because the rotor "hat" is made out of aluminum instead of iron it makes the whole rotor MUCH lighter. My 12.2" rotor was less than 1 lb. heavier than my 9.44" rotor!
Old Dec 2, 2002 | 06:47 AM
spoon_ek9's Avatar
Default Re: my new brake setup (Hondaddict)
i believe u have the kit from wilwood which use a dynalite caliper. mine is using superlite caliper which is a bigger one. the pad is bigger and thicker. wilwood one is good(cheap too) but it can't clear almost any 15" rim(w/o spacer)
Old Dec 2, 2002 | 08:54 AM
vtecvoodoo's Avatar
Future Texas Boy
Owen,
I`m using the 11" Wilwood kit and it rocks. Super happy with it. I actually enjoying changing the pads, it`s so freakin easy. Takes about 15 seconds per side
Ryan
superbike81
Suspension & Brakes
17
Oct 11, 2013 09:21 PM
skylinecx1212
Suspension & Brakes
Oct 5, 2012 04:07 AM
persain488
Sep 28, 2004 04:30 PM
DaiJekBok
Jan 15, 2003 07:52 AM
