put in air/fuel gauge......
put in air/fuel gauge and now car stays running rich. My question is .. is there anyway to turn the fuel pressure down with out a fuel pressure regulator,car is bone stock excpet for exhaust.
Well if it is a stock ECU, then you running rich is caused by something that needs to be fixed. In my manual for the Air/fuel ratio meter it says that if you notice that you are always running richer than normal, it could be your O2 sensor that is sending the ecu the wrong signal and makin it run rich. All 02 sensors go out over time. How many miles on you 02 sensor???
you cant determine if your car is running too rich. if you havent added anything or tampered with the fuel system then you shouldnt have a problem. get a fuel pressure guage and hook it up to your fuel line to test to make sure your fuel pressure is running at specs.
