S2000 seat install into civic with pics done properly. Very long, not 56k friendly.
Old Nov 30, 2002 | 08:40 PM
racecarpete's Avatar
Default S2000 seat install into civic with pics done properly. Very long, not 56k friendly. PICS FIXED!!
Wasup guys, well i got really bored tonight and decided to figure out how to put my s2000 seats in my car with all 4 bolt holes lining up. Heres the story, i've had my s2000 seats for about 6 months. In the s2000(car), the seats mount flat to the floor, so in order to mount them in a civic, most people bend the front two tabs and then 3 bolt holes line up. You can NOT just swap rails with these seats like with sol or teg seats do to the nature of the brackets and seat bottom but i found a way to do it. Now these seats are the nicest seats i have had, gone through a set of del sols previously but i am a perfectionist and it annoyed the hell out of me that i had only 3 bolts in. Most people didn't notice but the seat would slightly wobble when you got in. So, with a boring night at home, very tired, and not feeling like going out, this is what i did.
here is a pic of the back of the seat where it mounts, notice the outer left mounting tab and how it just hangs there.
here is a pic of the seats fully reclined forward, really sucks
***, due to the fact that they were designed for a roadster, they don't go forward or very far back, making it impossible for passengers to get in your car.
So my journey begins, you can not swap brackets, so i went to see if you could swap the entire hing over, no dice. here is why. the civic seat brackets mount to the side of the seat bottom
Wheras the s2k seat bracket mount crap mounts to the bottom of the seat bottom
So after a bit of scratching the head, i discovered that honda uses the exact same seat bottoms for it's seats with just different mounting points. so i proceded to take my s2k seat apart along with a junk civic seat.
Then you have to remove the hog rings from the seat bottoms to remove the metal seat bottom. After that you can swap the metal seat bottoms, here is a side by side comparison of the civic seat bottom and s2k seat bottom
(civic=left,s2k=right) if you notice, minus a few holes the only difference between the two seat bottoms is toward the outer top left and right. The s2k has a bolt sticking up and the civic has a round tube thingy welded instead.
here is another pic to show, civic top, s2k bottom
reinstall the seat bottom and hog rings and such.
now you will have to remove the entire hinging assembly. basically you have to kinda peel the leather up on the seat back until you can get to the two bolts hidden under the leather, there will be one hog ring you need to take out in the front part of the seat under the main cushion to make this easier.
After that, swap out the hinging assembly and the other seat rail and put everything back together and you should be set. here is a pic of the civic hing bracket crap installed, s2k hing crap thinging infront for comparison.
now your seat will be able to fully recline just like your stock seats and all bolt holes will line up. here is a pic of the passenger seat fully reclined forward after doing this and the driver side fully reclined forward untouched. Notice the big difference?
All in all, it took a while to do, wasn't too bad just damn time consuming. Well worth it cause the car is now functional again, it was impossible for anyone to get into the back and all of the holes are bolted in. hope this helps anyone that was wondering how to bolt your s2k seats in. Only con to doing this is, it raises your seat up a little bit but s2k seats are super low so i think i am right around del sol seat height now so it is ok. later
Old Nov 30, 2002 | 08:42 PM
oldB18EF's Avatar
Default Re: S2000 seat install into civic with pics done properly. Very long, not 56k friendly. (SilverCivic
awesome dude. Im sure this will help some ppl
Old Nov 30, 2002 | 08:44 PM
i'm kinda wondering now, if the same principal can be applied to prelude seats.
Old Nov 30, 2002 | 08:57 PM
Daniel's Avatar
i can't see pics, but the write-up sounds nice.
Old Nov 30, 2002 | 08:58 PM
Yamzz_EG's Avatar
yeah it does but i want to see pics sounds like it would be tight
Old Nov 30, 2002 | 09:00 PM
damn is everybody having trouble seeing the pics?
Old Nov 30, 2002 | 09:04 PM
CunninLynguist's Avatar
cant see any pics
Old Nov 30, 2002 | 09:10 PM
did we-todd-did-racing go down? that is where i had the pics and now i can' access them. Will be fixed soon, uploading to imagestation.
Old Nov 30, 2002 | 09:30 PM
Daniel's Avatar
i can see two of the pics now. the rest are still the infamous red X for me.
Old Nov 30, 2002 | 09:39 PM
all pics should be up now. What do you guys think?
Old Nov 30, 2002 | 09:41 PM
johnzm's Avatar
i got htem all except 2. one is mis-link and other is X. dude, i dont think i could bring myself to rip apart s2k seats like u did lol
Old Nov 30, 2002 | 09:49 PM
Daniel's Avatar
OMFG! that's awesome! the pics illustrate the process very well, and the write-up is excellent. Makes me want to go out and get some S2K seats now -- which i've been wanting forever but i lack the cash. Good stuff, man! they look right at home in your civic.
[Modified by Daniel, 6:50 AM 12/1/2002]
Old Nov 30, 2002 | 10:00 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: S2000 seat install into civic with pics done properly. Very long, not 56k friendly. PICS FIXED!!
awesome seats bro, you rock
Old Nov 30, 2002 | 10:04 PM
tommyboy's Avatar
Very nice.
Old Nov 30, 2002 | 10:08 PM
six.lug.steph's Avatar
nicely done
Old Nov 30, 2002 | 10:12 PM
LOSERboy's Avatar
Whoa.............that is CLEAN
Old Nov 30, 2002 | 10:18 PM
anjapower's Avatar
Impressive
How long did that take you?
Old Nov 30, 2002 | 10:19 PM
thanks guys. I really don't even know how long it took. I was only able to do the passenger seat cause the driver civic seat has that damn adjustment crap ***** on the side and i can't use it. I don't think it took more than 45 min to an hour but i was on the phone, and watching tv and eating so who knows.
Old Nov 30, 2002 | 10:32 PM
mr poo's Avatar
cant believe you took the seats apart juss to see if it'd work! (applauds)
Old Nov 30, 2002 | 11:25 PM
Halo's Avatar
good information there......thanks man
Old Nov 30, 2002 | 11:49 PM
ahcjar103's Avatar
good stuff. s2k seats are
Old Dec 1, 2002 | 03:35 AM
CristalCleanCivic 97 EX's Avatar
How long did it take u?
And that's a 2000 civic, right? Not the new model? Just checking.
Very cool mod. and its nice to know all that work for u payed off!
U get my PIONEER AWARD ! hehe!
Old Dec 1, 2002 | 03:41 AM
That's a 2000 civic, right? Not the newer model? Just checking..
Cool mod. Nice to know that all that work paid off!
[Modified by CristalCleanCivic 97 EX, 12:41 PM 12/1/2002]
Old Dec 1, 2002 | 08:08 AM
yes this is a 2000 civic, took maybe an hour for one seat, somebody had to do it sooner or later, i just got really bored and decided what the hell.
Old Dec 1, 2002 | 08:12 AM
pennies_hatchie's Avatar
really cool, now if only i had s2000 seats
