What rear sway bar do you have?
Old Nov 30, 2002 | 08:01 PM
Calavera's Avatar
Default What rear sway bar do you have?
What swaybar do you have in your ITR? And what do you usually do with your car: daily driver, track, auto-x?
The front sway bar is 24mm by default, correct?
Old Nov 30, 2002 | 08:08 PM
Ferrell's Avatar
Default Re: What rear sway bar do you have? (Calavera)
stock. DD
Old Nov 30, 2002 | 08:10 PM
thk's Avatar
thk
Members Only
Currently still stock. I'll probably try the 23mm sometime next year and see if I need something bigger after that.
Old Nov 30, 2002 | 10:19 PM
Calavera's Avatar
Default Re: What rear sway bar do you have? (thk)
i thought alot of ITR owners went with 26mm mugen sway bars....I guess not.
Old Nov 30, 2002 | 10:57 PM
Art Vandeleigh's Avatar
so far i dont think i have improved enough as a driver to warrant upgrading the suspension or the sway bar. at the autox i find the oem setup perfect and have not needed anything changed.
oem=
but i would love to drive a car with a 26 in the rear or a 23 even.....
art - who needs to improve his driving skills....
[Modified by Art Vandeleigh, 7:57 AM 12/1/2002]
Old Dec 1, 2002 | 12:50 AM
Looose_R's Avatar
no bar on my ride, maybe ill try my itr bar on the new ride, but i like hte under steer
Old Dec 1, 2002 | 03:29 AM
arren123's Avatar
I had to go with the 26mm Mugen bar to offset the understeering effects from going to the stock suspension to the Lowdowns.
Old Dec 1, 2002 | 06:21 AM
D's Avatar
D
mugen 26 in the rear.
Old Dec 1, 2002 | 06:40 AM
EleanoR's Avatar
Default Re: What rear sway bar do you have? (D)
JDM 23mm
Old Dec 1, 2002 | 08:29 AM
4-1-1's Avatar
Default Re: What rear sway bar do you have? (EleanoR)
stock for now............
Old Dec 1, 2002 | 09:32 AM
Chris N's Avatar
Default Re: What rear sway bar do you have? (4-1-1)
23mm...
Old Dec 1, 2002 | 09:36 AM
Willard's Avatar
23mm rear... with a 21mm front.
Old Dec 1, 2002 | 09:37 AM
Hooch'n's Avatar
Default Re: What rear sway bar do you have? (Willard)
stock.........
Old Dec 1, 2002 | 12:09 PM
mugen76's Avatar
Default Re: What rear sway bar do you have? (Hooch at 8400-RPM)
not an ITR but i have a comptech sway/tie combo
Old Dec 1, 2002 | 01:13 PM
Warren's Avatar
Wrong-Way Wang
Saner 24mm, but it mounts further outboard. Effectively stiffer than the Mugen 26mm, which I've run before.
Warren
Old Dec 1, 2002 | 01:28 PM
Paste's Avatar
Loved
Default Re: What rear sway bar do you have? (Warren)
Warren
Hmm, sounds interesting...
Old Dec 1, 2002 | 01:31 PM
kungfuSiR's Avatar
Default Re: What rear sway bar do you have? (paste)
Type R rear, replaced my dinky SiR one, and have loved the TypeR one since
Old Dec 1, 2002 | 05:17 PM
DarthLuder's Avatar
New User
Old Dec 1, 2002 | 05:26 PM
Joker's Avatar
Default Re: What rear sway bar do you have? (ITR GURU)
Stock/daily driver
[Modified by Joker, 6:26 PM 12/1/2002]
Old Dec 1, 2002 | 06:41 PM
Calavera's Avatar
Default Re: What rear sway bar do you have? (Joker)
who voted for custom sway bar??
Old Dec 1, 2002 | 07:17 PM
Hybrid ctr's Avatar
probably Warren
Old Dec 1, 2002 | 07:50 PM
Mugen Mike's Avatar
m00gen. All the above
Old Dec 2, 2002 | 06:46 PM
spoonee's Avatar
Default Re: What rear sway bar do you have? (MugenMike)
stock here....
Old Dec 2, 2002 | 07:19 PM
Calavera's Avatar
Default Re: What rear sway bar do you have? (spoonee)
Anyone ever spin out the rear because of the thicker swaybar like jdm and mugen...etc?
Old Dec 2, 2002 | 07:20 PM
Reid's Avatar
Global Moderator
Cars don't spin out by themselves.
Spin outs are driver error.
