what is code 15?
Old Nov 30, 2002 | 07:39 PM
bluedelsol's Avatar
Default what is code 15?
i am getting code 15 in my 94 del sol S (d15b7) what does it mean? well it may be 16 not shure, the light blinks one time real quick when i turn the key then stays on for a second and then blinks 5 times, i think that means 15?
[Modified by bluedelsol, 4:41 AM 12/1/2002]
Old Nov 30, 2002 | 07:45 PM
Chiovnidca's Avatar
Default Re: what is code 15? (bluedelsol)
Code 15 = ignition output signal. Check that the connectors on the igniter are good and tight.
Old Nov 30, 2002 | 08:16 PM
bluedelsol's Avatar
Default Re: what is code 15? (Chiovnidca)
that fixed it, i have an MSD sci ignition controller and an external coil and my crapy wireing job only lasted a few mounths, there was just a wire lose going to my coil. thanks alot, i owe you one
civicboy420
Sep 25, 2011 06:05 PM
jmeyer99
Aug 2, 2007 10:18 PM
90crvtec
Aug 19, 2005 07:19 PM
