prelude timing belt
Old Nov 30, 2002 | 06:13 PM
79 civic's Avatar
Default prelude timing belt
I just did a timing belt water pump change on my non vtec prelude. The timing belt keeps walking off of the cam gears. Nothing seems to be warped, everything is tightened and torqued to spec. Any ideas?
Thanks
Old Nov 30, 2002 | 06:56 PM
Spartanic's Avatar
Default Re: prelude timing belt (79 civic)
probably have to retighten your belt tensioner. First turn the crank counterclockwise until it takes off the slack on the belt, then tighten up the tensioner bolt. You may have to lift it up.
Old Dec 1, 2002 | 07:12 AM
79 civic's Avatar
Default Re: prelude timing belt (Spartanic)
The timing belt seems to be correct, I have done it like the manual said, and then by pulling on the tensioner to make the belt tighter as well. When I turn the engine over by hand the belt stays put, but when it is turned over by the starter it works it's way off.
dleccord
Apr 13, 2020 08:03 AM
chahsiubow
Dec 14, 2007 10:01 PM
OzWolfbane
Jan 7, 2005 05:14 PM
1slow_si
Sep 23, 2004 02:34 PM
eddiecut
Jun 16, 2003 12:10 PM
