Need help with some suspension problems.
Old Nov 30, 2002 | 05:04 PM
RockDawg_GSR's Avatar
Default Need help with some suspension problems.
Hey guys whats up? I have a question for you guys. U know how u can get a camber kit for integras, do they sell adjustable upper control arms( i think thats what its called). I got in a accident awhile ago and my lower control arm was bent really bad. I replaced that aswell as a few other parts. After all of this, my drivers side rear wheel was still not looking like it was supposed 2 be. I think the caster is fuked up( the top of the wheel is sticking in too much), but it might be camber. Ummm.... basically my dad asked if any company made a adjustable upper arm. Its the arm that is a single rod, above the lower control arm sort of in a horizontal position. If you guys know of any companies that make that arm adjustable please let me know. Or maybe like a whole camber kit that would include that arm as well. Please e-mail me or just reply 2 this post..Thanx a lot guys..
Old Nov 30, 2002 | 05:28 PM
IN VTEC's Avatar
Default Re: Need help with some suspension problems. (RockDawg_GSR)
Take it in for an alignment and they'll take care of it (using washers to shim the upper arm outwards). It should be an easy fix as long as there's no extensive damage.
If the upper arm is bent, then you'll have to replace it to get the camber back into spec. If that's the case, I've got a pair of spare rear upper arms.
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
Honda knowledge
Apr 15, 2015 10:41 AM
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
matt1982
Mar 17, 2007 09:45 AM
idreamHonda
Suspension & Brakes
Apr 16, 2005 01:44 PM
