New injectors.
Old Nov 30, 2002 | 10:40 AM
Tegra's Avatar
Default Injector Help!
I have a 95 LS and one of my injectors is leaking. It's putting gas into my oil. I'm going to get 4 new ones, but I was wondering if I should what brand/size should I get. Should I go up to 270cc? All I have on my car is i/h/e. Would the bigger injectors help or hurt?
[Modified by Tegra, 2:16 PM 11/30/2002]
Old Nov 30, 2002 | 11:25 AM
Jesse H's Avatar
Default Re: Injector Help! (Tegra)
How is it putting gas into your oil? The injectors are no where near any oil sources.
Have you tried replacing the injector seals yet?
Old Nov 30, 2002 | 12:29 PM
Tegra's Avatar
Default Re: Injector Help! (Jesse H)
Seeps from the injector into the cylinder, past the rings, into the crank. This happens while the engine is off.
Old Nov 30, 2002 | 12:57 PM
Padronis's Avatar
I would go with what Jesse H said. At least try that at first.
Old Nov 30, 2002 | 05:20 PM
IN VTEC's Avatar
You don't want bigger injectors unless you have an AFC.
king06
Jan 20, 2018 11:13 AM
B16Drag
Apr 18, 2009 08:10 PM
5gen-hybrid
Jan 13, 2002 10:45 PM
