newbie question
How do change out spark plugs? Does it require you to remove the head cover? I don't have an owner's manual for my 96 ex, and when I removed the plug wires from the head cover the spark plugs are way down there. Sorry for the dumb question.
ok, i'll help.
Take the plug wires, but do one spark plug at a time, you need a large socket (don't know the size) and take the plugs out, and change it with a new, be carefull when putting the new plug back in, try to not tight it much, i think it should be from 16 - 20 Ft-lbs, but don't quote me on that. Another thing, if you kinda like to rev your engine and you are on a hot climate, you could use one step colder plugs, the code is on the hood sticker inside (here they are: NGK: ZFR6F-11 or ND: KJ20CR-L11) but it's not something you NEED. if you need any more info IM me.
[Modified by GZERO, 2:21 PM 11/30/2002]
Yes, get the spark plug sockets, they have a rubber insert inside that will hold the plug in the socket as you take them out or put them in. THey also help from cracking the plugs. They should be thightened to 13 lbs. And also, get a cheap extension and duct tape the socket to the extension. A small piece of duct tape will save you the frustration that comes from the socket getting stuck on the plug.
yeah dude, you gotta pull the head. lube the muffler bearings - check your flux capacitor make sure you aren't leaking time travel juice.... you also have to move your muffler filter out of the way... then you might fix it?
we need more helpful people like this
We were all in that spot once, and if no one would have teach you, you wouldn't know a thing. Lets make H-T.com a great place to learn and ask questions we don't know. and if you know everything, then what are you doing here loser?
What is the difference between "taper seat" and "gasket type", and which specification should I use when tightening?
On the ngk zfr5f-11 plugs it says 18-21 lb/ft for gasket type, and 7-14 lb/ft for taper seat. Thanks for the help.
[Modified by llama, 11:26 PM 12/2/2002]
WHY DO THIS?! yeah sure, you were never a newbie! don't be a jerk
We're not all jerks around here. But for the spark plug tech, someone else will answer, I don't know myself...Sorry
ok, i think, and don't quote me, i'm not sure, hell, i think i'm even inventing this, but the gasket type is the one that has the metal gasket, and the taper seat is the one that doesn't have it, this is really a bump, not the actual fact, hehe
