will 99 si shocks fit on a 93 hatch
Old Nov 29, 2002 | 07:09 PM
B_1_8_hatch's Avatar
Default will 99 si shocks fit on a 93 hatch
just wondering if they would work?
93hb
Old Nov 29, 2002 | 08:51 PM
mantic6t9's Avatar
Default Re: will 99 si shocks fit on a 93 hatch (93hb)
The front shocks will but the rear shocks will not. The front shocks will not have mounting bracket for the brake lines, you will have to zip tie them out of the way.
EDIT: you can sand/grind/cut the rubber bushings down on the hatches LCAs to make the correct width for the 99 rear shocks. The rear shock has a narrower mounting bracket and will not fit the "eg" LCAs without modification.
[Modified by mantic6t9, 11:55 PM 11/29/2002]
zdalunatic
Oct 9, 2007 04:49 PM
mrchris1979
Suspension & Brakes
Sep 17, 2007 05:36 AM
hatch808
Aug 10, 2003 02:31 PM
letsride
Sep 5, 2002 02:38 PM
