JDM ITR motor problems
Old Nov 29, 2002 | 03:06 PM
jdmrealm's Avatar
New User
Default JDM ITR motor problems
I have a JDM ITR motor in my 98 DX.
Here is a dyno:
This was with a bad rotor. I changed the rotor and broke the distributor and I got 153 whp and 98 tq.
Now I got a new distributor. So I should be putting down some more but thats still not what it is supposed to put down. Torque is lower than a b16.
Im guessing maybe fuel pump....cause i have a stock civic fuel pump.
Does anyone know what pin on the JDM P73 is for the o2 signal?
Thanks
Old Nov 29, 2002 | 06:33 PM
skunkwhat's Avatar
Default Re: JDM ITR motor problems (ej6)
If your civic fuel pump is working correctly you should have no problems, with getting the fuel there.
Do you not have the o2 hooked up? How does it run? What have you tried? Need more info to many variables.
Old Nov 29, 2002 | 06:36 PM
Downey's Avatar
thats really low hp and torque. my d16 put down 110 torque.
try doing a compression and a leak down test.. u might have a problem
Old Nov 29, 2002 | 09:41 PM
-Darren-'s Avatar
where you get that motor from?
Old Nov 29, 2002 | 11:35 PM
ill phil's Avatar
Default Re: JDM ITR motor problems (star&buc)
Yeah, the civic fuel pump should still be able to handle it unless it is actually just a bad fuel pump....
You done a compression check or anything like that? Possibly for spark, fuel pressure, etc. Those #'s are way low....
Old Nov 30, 2002 | 01:10 AM
Zeus Zore's Avatar
Default Re: JDM ITR motor problems (ill phil)
well tha ITR here does only 175-185 HP(180 = some 155WHP) on the flywheel..(whats of with that diffrens)
they are set at 2 high HP then they really do !!
and if you are running stock and not with the best parts-broken...
well i would say that fair
the TQ i dont know what is here and we do it in NM or KGm !!
Old Nov 30, 2002 | 01:22 AM
ahcjar103's Avatar
Default Re: JDM ITR motor problems (Zeus Zore)
[Modified by ahcjar103, 10:23 AM 11/30/2002]
Old Nov 30, 2002 | 01:59 AM
hatchback's Avatar
I am curious as well, where did you get the motor from?
Old Nov 30, 2002 | 09:05 AM
SpooN Man's Avatar
Default Re: JDM ITR motor problems (hatchback)
That sucks, my b18c1 just put down 155 and 115.
Old Nov 30, 2002 | 09:41 AM
Nameless RB26's Avatar
Default Re: JDM ITR motor problems (SpooN Man)
something is wrong there.. really.
DO YOU HAVE A CEL? If so, then your ecu is more than likely making it run like that... depending on the code.
Old Nov 30, 2002 | 09:46 AM
Jawad.'s Avatar
where did your purchase your jdm itr motor from?
Old Nov 30, 2002 | 09:56 AM
sleeprhatch's Avatar
Default Re: JDM ITR motor problems (Jawad)
what year is that motor? something is wrong. do a compression test and check voltage at the O2 sensor. (O2 pin is the same as your harness.) Are you positive it is a p73 ecu?
Old Nov 30, 2002 | 10:19 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: JDM ITR motor problems (sleeprhatch)
Weird, my B18C5 put down 175whp and 123 torque with only intake, exhaust, and re-chipped P28 ECU.
What kind of car do you have it in?
What engine harness are you running?
What ECU?
Any CELs?
We need more info! Help us help you!
Old Nov 30, 2002 | 03:16 PM
jdmrealm's Avatar
New User
Default Re: JDM ITR motor problems (B18C5-EH2)
What ECU?
Any CELs?
Its in a 98 DX. I bought the car with the swap.
No CEL. ECU is a JDM p73, I put my friends JDM p73 in there and it still ran the same.
I have no idea what engine wiring harness it has.
I have changed the plugs already did nothing. I want to get complete new wiring harnesses but I dont know which one to get for a 98 dx wit a JDM ITR.
The motor is a 97.
Thanks
[Modified by ej6, 12:20 AM 12/1/2002]
Old Nov 30, 2002 | 03:47 PM
you should check to make sure the previous owner didn't take out the bulb for the check engine light.
When you turn the key before cranking the car does it appear?
Old Nov 30, 2002 | 03:49 PM
jdmrealm's Avatar
New User
Default Re: JDM ITR motor problems (Nameless)
The CEL works, when I unplug a sensor it comes on.
Old Nov 30, 2002 | 03:58 PM
rainmanEK's Avatar
big strong guy
Get a 96-00 ex harness ( engine ) then all you need to do is wire in knock sensor, It will al ready have vtec wired!!
eric
Old Nov 30, 2002 | 04:06 PM
fowler!'s Avatar
Default Re: JDM ITR motor problems (rainmanEK)
eric
96-98. He can't use anything newer unless he gets jiggy with the wiring.
Old Nov 30, 2002 | 04:07 PM
fowler!'s Avatar
Does vtec engage?
Old Nov 30, 2002 | 04:08 PM
jdmrealm's Avatar
New User
Default Re: JDM ITR motor problems (fowler)
Does vtec engage?
Yes vtec engages.
MPower332TI's Avatar
It already has the knock sensor wired also. (96-98 ex) Good luck
Old Nov 30, 2002 | 04:11 PM
jdmrealm's Avatar
New User
The cars lights dim and get bright according to rpm and weather im on the throttle. Im guessing this "electrical" problem isnt getting enough power to the fuel pump and im not getting enough fuel because of that.
Does anyone know what pin the o2 sensor signal is on the JDM P73, I want to hookup an air/fuel gauge and see if im running lean or not.
Old Nov 30, 2002 | 04:28 PM
Hows the alternator? If your lights are going dim and getting brighter when you accelerate, you may have a bad diode/s in the alternator. Is your engine grounded properly? (you really should check that). This stuff may sound stupid, but it's important to know...
Is the idle ok?
Old Nov 30, 2002 | 04:37 PM
jdmrealm's Avatar
New User
I had an alternator...charging system check done...all is fine.
Grounding....I have grounds but the one by my tranny sparks sometimes when I start it...I took it off cleaned it but still no difference.
Sometimes idle drops low to about 400-500 rpm and car wants to stall...This happens once in a while
Old Nov 30, 2002 | 04:48 PM
It sparks? lolol. Is it like fireworks? How can you see it when you start the car?
Maybe try a new fuel filter too? I dunno.. gotta take it into the shop I guess.
