Why are the Mid lobes on the intake and exhaust camshafts...
Why are the Mid lobes on the intake and exhaust camshafts for the SH 'taller' than the base models? Does it get more oomf somewhere along the way?
I found in the Helm manual section 6-34 the list and it shows that the MID lobe (intake) on the SH is 37.229 mm while the MID lobe on the Base (manual or SS) is 36.856 mm. The MID lobe (exhaust) on the SH is 36.704 mm while the MID lobe on the Base (manual or SS) is 36.323 mm.
I thought that the two models were basically the same except for the suspension and ATTS ?
What exactly does this do for the SH model?
[Modified by kotetu, 10:50 PM 11/29/2002]
that is the vtec lobe, i wasn't aware it had more lift on the sh model, maybe that was their way of making up for the extra weight in the sh...i dont think that it is enough difference that you would be able to tell the difference...anyone have the type-s specs to compare to?
TYPE SH:
IN EX
DURATION @ 0.50"
225 227
GROSS LIFT w/ 1.55
.448 .415
JDM/USDM H22A/H22A1/H22A4 base:
DURATION @.050"
224 224
GROSS LIFT w/ 1.55
.446 .415
source: CROWER
note: I'm assuming that the cams in the H22A, H22A1, and H22A4 (base) are the same
[Modified by JDM LUDE, 1:15 AM 11/30/2002]
IN EX
DURATION @ 0.50"
225 227
GROSS LIFT w/ 1.55
.448 .415
DURATION @.050"
224 224
GROSS LIFT w/ 1.55
.446 .415
source: CROWER
thanks, It's as I thought. Extra weight and a little extra power to make up for it. I wonder how much it does make up for? hm
Not enough really. Most SH are slower in the 1/4 mile than a base.
if you had a set of these laying around would you take the time to swap out the cams? think you could even tell?
btw- srv how long till you have her back on the road
. My fucked engine hasn't even been opened. Once we clean it out..3 weeks but I'm doing I whole bunch of stuff now...I just sold my leather seats and I'm doing a bunch of interior stuff....
sh's were rated at 205 in 2000, with the base rated at 200.
1997 spec is 200 sh, 195 base. the power increase in 1999 was due to a redesign of the exhaust collector.
the SH is only 90lbs heavier than the base. the 5hp was designed to help offset the weight difference, but also to help overcome the action of the ATTS system, which is a big power robber.
if you change to a
duration @.050
230/224
what would be the differents?
[Modified by LJR-LUDE01, 10:35 PM 12/1/2002]
[Modified by LJR-LUDE01, 10:36 PM 12/1/2002]
duration @.050
230/224
