Vacuum ? on the b16a2
Old Nov 29, 2002 | 01:29 PM
VTEC-DA's Avatar
Default Vacuum ? on the b16a2
The box that sit on the bottom of the runners on the intake maniflold. Its black and has one electrical connector in it and a vacuum line on each side. Where do those vacuums go? I have the one on the right side going to the top on the intake manifold, but where do I run the one on the left side?
Old Nov 29, 2002 | 03:09 PM
VTEC-DA's Avatar
Default Re: Vacuum ? on the b16a2 (non-turbo2dr)
bump
Old Nov 29, 2002 | 05:36 PM
VTEC-DA's Avatar
cmon, someone has to know
Old Nov 29, 2002 | 05:38 PM
ITR607's Avatar
New User
are you talking about the breather for the oil system?
Old Nov 29, 2002 | 05:49 PM
VTEC-DA's Avatar
Default Re: Vacuum ? on the b16a2 (ITR607)
I lost my Helms manual so I dontk now what its called. Its a black box with a vacuum port on each side and an electrical port on top of it. It sits right at the bottom of the runners in the middle of the intake manifold.
Old Nov 29, 2002 | 05:53 PM
DragII's Avatar
25 Year Member
are you talking about the one that is connected to the fuel injectors?
Old Nov 29, 2002 | 06:03 PM
VTEC-DA's Avatar
Default Re: Vacuum ? on the b16a2 (Tetsuo)
The box itself bolts to the fuel rail, not the intake manifld, my bad on that. The electrical connector going to it is part of the same wiring harness that the injetor wiring is. Like, the 8 injecor wires and the 2 wires from this sensor all meet bind together.
Old Nov 29, 2002 | 08:58 PM
VTEC-DA's Avatar
Bump. Where does the vacuum line go? One end on the left side of this black box, and the other end ???.
Old Nov 30, 2002 | 12:17 AM
92b16vx's Avatar
The only vacuum hoses I know you need are the ones from the map sensor and the blowby(which can be replaced with cute lil filter) everyother one should go to the charcoal canister or some other useless emmisions device,which I see people remove entirely and use vacuum plugs.Of course this is for obdI edm b16a2 which I wouldn't think is any different than that one.So if yours is a obdII disregard
Old May 26, 2004 | 09:11 PM
iNetForce's Avatar
Default Re: Vacuum ? on the b16a2 (92b16vx)
was this problem solved? I need the same info.
AudioFunk
Apr 9, 2015 07:40 AM
blacktibby07
May 27, 2011 06:23 PM
Lewdin' Incognito
Sep 2, 2005 03:44 AM
B00ST2nR
Nov 5, 2003 12:49 AM
Firedrake
Jul 17, 2002 11:44 AM
