Vacuum ? on the b16a2
The box that sit on the bottom of the runners on the intake maniflold. Its black and has one electrical connector in it and a vacuum line on each side. Where do those vacuums go? I have the one on the right side going to the top on the intake manifold, but where do I run the one on the left side?
Re: Vacuum ? on the b16a2 (ITR607)
I lost my Helms manual so I dontk now what its called. Its a black box with a vacuum port on each side and an electrical port on top of it. It sits right at the bottom of the runners in the middle of the intake manifold.
Re: Vacuum ? on the b16a2 (Tetsuo)
The box itself bolts to the fuel rail, not the intake manifld, my bad on that. The electrical connector going to it is part of the same wiring harness that the injetor wiring is. Like, the 8 injecor wires and the 2 wires from this sensor all meet bind together.
Re: Vacuum ? on the b16a2 (non-turbo2dr)
The only vacuum hoses I know you need are the ones from the map sensor and the blowby(which can be replaced with cute lil filter) everyother one should go to the charcoal canister or some other useless emmisions device,which I see people remove entirely and use vacuum plugs.Of course this is for obdI edm b16a2 which I wouldn't think is any different than that one.So if yours is a obdII disregard
blacktibby07
05-27-2011 06:23 PM
Firedrake
07-17-2002 11:44 AM
